Thread: Intake Manifold torque specs
Results 1 to 5 of 5
  1. #1 Intake Manifold torque specs
    Cicero
    hi guys im putting together my 97 grand prix intake gasket, can someone tell me the torque specs to use for the upper and lower gasket bolts, and i alos need the torque specs for the rocker arm bolts if any, please help, its a 3.1 v6 SFI.
  2. #2 Re: Intake Manifold torque specs
    89 in lbs + 30 degrees for rocker bolts, you need to buy new ones.
    lower intake bolts are 62 in lbs then 115 in lbs.
    cant find any mention of the upper.
  3. #3 Re: Intake Manifold torque specs
    Cicero
    im sorry, can you tell me in ft lbs, and what does 30 degrees mean. and on the lower bolts, why do i need to tighten them twice, or what u mean by 62 then 115. im mostly worried bout the rockers and the lower, but im not good with the conversion, so do you know the FT lbs.
  4. #4 Re: Intake Manifold torque specs
    just German them theyll be fine
    SMGPFC Member #10
  5. #5 Re: Intake Manifold torque specs
    From the PM:
    divide by 12 and theres ft lbs.
    typically if the numbers are in inch lbs, its because a typical ft lb torque wrench wouldnt be accurate at those levels.
    30 degrees means you must use an angle meter and turn it 30 degrees.
    You tighten twice to prevent warpage and ensure even pressure. what you do is tighten from the inside out to 62 inch lbs on the first pass, then 115 on the second.
    Again, ft lbs wont help you much.
  1. LIM torque specs
    By 98 GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 11:25 PM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. Intake manifold gasket torque specs
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2010, 06:23 PM
  4. need torque specs for...
    Last Post: 04-17-2008, 12:16 AM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
