Thread: Stalling problems
Results 1 to 9 of 9
  1. #1 Stalling problems
    Oct 2011
    Kennewick, WA
    My 91 Grand Prix is having some issues. On start up, it will rev really high for about 30-40 seconds. It will then go back down to regular idle speeds while its still in park. As soon as I shift it out of park though, it will start shaking and sputtering until I step on the throttle. When I open up the throttle going down the road, it will do just fine at normal speeds. But when I start to slow down to come to a stop, it will start acting up again. When I come to a stop, the engine will shake for a few seconds, and then promptly die. Any suggestions?
  2. #2 Re: Stalling problems
    new britain, ct
    sounds like a misfire of epic proportions. check all your plugs and wires.
    maybe a huge vacuum leak as well.
    07 Black GXP.
  3. #3 Re: Stalling problems
    Oct 2011
    Kennewick, WA
    Alright, I'll try that.
  4. #4 Re: Stalling problems
    new britain, ct
    any updates?
    07 Black GXP.
  5. #5 Re: Stalling problems
    GTX Level Member cerick08GP's Avatar
    Just going of what little information that has been given so far, I’m going with a gummed up throttle body or a faulty MAF sensor.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: Stalling problems
    Oct 2011
    Kennewick, WA
    There doesn't seem to be anything wrong with the plugs or the wires, and i can't find any vacuum leaks for the life of me. I think i might change the maf sensor to see what that does. Otherwise, i'll just assume its the throttle body.
  7. #7 Re: Stalling problems
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    any engine codes? code 42? or maybe idle air control sensor
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  8. #8 Re: Stalling problems
    Minnesota
    IAC probably. I would try cleaning your throttle body.
  9. #9 Re: Stalling problems
    Oct 2011
    Kennewick, WA
    The problem seems to have resolved itself. I ran some fuel system cleaner throug, and everything seems to be working fine now.
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. 1995 stalling problems
    By Hawxby06 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-27-2010, 11:07 AM
  3. Random Stalling Problems - PLEASE HELP!!!
    By teamramrodd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 03:31 PM
  4. Terrible stuttering/stalling problems
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2009, 11:54 PM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
