Thread: spark intermitent 1997 3.1L grand prix se
Results 1 to 6 of 6
  1. #1 spark intermitent 1997 3.1L grand prix se
    SE Level Member tipatalon's Avatar
    quebec
    hi there, hope you guys can help with this one, i have a 97 grand prix se that was running like a charm. about 2 weeks ago i did LIM gasket and was running fine after, but yesterday the car won't even start, after 3 or 4 attemps the car started but shut instantly. fuel is ok, but spark is intermitent, what can cause this?
  2. #2 Re: spark intermitent 1997 3.1L grand prix se
    SE Level Member midniteblu02's Avatar
    Howe, Indiana
    maybe just a poor connection in the ignition system? Or possible problem in the crank sensor circuit?
    Gen V | N*| VS cam | Meth | SLP Headers/ catback | Shift Kit
  3. #3 Re: spark intermitent 1997 3.1L grand prix se
    quebec
    ignition checked, changed spark wires and plugs, also crank sensor, cam sensor, but still have this problem! how to check vaccum leaks?
  4. #4 Re: spark intermitent 1997 3.1L grand prix se
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    spray around with carb cleaner and listen for the engine to rev up..
    which you cant do if its not running.
    i dont think a simple vacuum leak would kill the car tho
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  5. #5 Re: spark intermitent 1997 3.1L grand prix se
    Quote Originally Posted by Austins01GP View Post
    Shenanigans.
    If its bad enough...it sure can.
  6. #6 Re: spark intermitent 1997 3.1L grand prix se
    Nov 2010
    Maryville, MO
    Shenanigans.
    really? like at the track it killed brians car when the LIM was gone but it was able to be restarted i feel like it would work the same way.
    i am an idiot tho
    // 2005 Comp G
  1. 1997 Grand Prix Idle
    By 1997Madscientist in forum General Tech Discussion
    Last Post: 07-10-2011, 04:39 PM
  2. 1997 grand prix gtp's
    By zildjian102 in forum The Rant Forum
    Last Post: 02-26-2011, 12:09 PM
  3. 1997 Pontiac Grand prix SE
    By bizzy187 in forum Visual/Body Modifications
    Last Post: 05-14-2008, 11:25 AM
