Thread: u bend delete
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 82
  1. #1 u bend delete
    Jul 2011
    United States
    u bend delete for a 2002 grand prix se 3.1L.... do they make a drop in? where can i get one?
  2. #2 Re: u bend delete
    Milzy Motorsports - American Muscle, Reborn under exhaust section last on the list
    have to get a new dp or make or get one made for you
    SMGPFC Member #10
  3. #3 Re: u bend delete
    Jul 2011
    United States
    dp, you good....
    /thread
  4. #4 Re: u bend delete
    nah, just the only one on here that cares about the 3100,
    SMGPFC Member #10
  5. #5 Re: u bend delete
    New York
    I have the u bend delete and a magnaflow cat back dual exhaust that I put on my single exhaust 3.1 2001 GP. It made a hugh difference in the power from the 3.1. i have had a 3.8 1998 GP, a 2004 Impala LS with the 3.8 (single exhaust), and my Dad's Buick LeSabre 3.8 with single exhaust. The 3.1 with the magnaflow duals and the u bend delete now has the power of the aforementioned 3.8's with the single exhaust! The 3.1 is a great motor that delivers excellent highway and combined fuel economy. Don't listen to the 3.1 nay sayers.
  6. #6 Re: u bend delete
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Quote Originally Posted by jbamonte View Post
    i have a 05 impala LS, it had single exhaust, i got dual exhaust from 2008 Impala SS with a 5,3l. i always thought dual exhaust was just for looks, your telling me i gained some horse power? good to know!
  7. #7 Re: u bend delete
    Jul 2011
    United States
    Quote Originally Posted by Grimsin View Post
    it depends on the most restrictive point in your exhaust (IE if point A is further up the pipe than be then if only so much air can go through point A then increasing the flow ability of point B won't help much if it isn't restrictive yet) but it most likely did help a bit
    edit: sorry for double post, he posted the thing about the exhaust while i was typing out the other post
  8. #8 Re: u bend delete
    St Thomas Ontario
    well i have cold air intake(filter is in my bumper) ubend delete, and the dual exhaust. next will be Plog and a downpipe.
  9. #9 Re: u bend delete
    yes, thank you
    im getting tired of being the only one who gives a damn about our little motors
    SMGPFC Member #10
  10. #10 Re: u bend delete
    Donating Users
    Jun 2010
    Rochester, NY
    I just did the u bend delete in combination with upgrading to a 56mm throttle body. I am very happy with the results.
  11. #11 Re: u bend delete
    Jul 2011
    United States
    yes, thank you
    seems like their is actually a group on here that cares for the 3.1l! yay!!! i plan on getting a 3.8 a little down the road but for now my 2002 GP SE is doing fine and has some serious pep! heck i just beat a 3.8l v6 on the highway about half an hour ago... then again hes bone stock and i now have a ncie CAI, 56mm TB, new exhaust, and am in the process of a tune (so far i just opened up the limiter and drew out the shifts a bit) i pulled ahead a bit at first and held it until he hit his speed limiter (i know he did because he stopped accelerating and i didn't), did it a couple times with the same result! i keep telling him to get a CAI, exhaust and a few other cheap upgrades but hes not nearly as into performance as anyone on here
  12. #12 Re: u bend delete
    The constant LIM and head gasket issues in addition to the lack of aftermarket make it quite the turn-off.
  13. #13 Re: u bend delete
    Quote Originally Posted by dwarmbrodt View Post
    very nice, im doing trhe same thing at the end of the month
    just an fyi, im at 107k and an 9 year old car and still all stock gaskets, of corse with all the perventative mantence, so in my experience has long as you take care of them then you dont have to worry about that all to much
    SMGPFC Member #10
  14. #14 Re: u bend delete
    New York
    Nope!
    The 3.8's and the 3.1's both have the same incidence of LIM and head gasket issues, the 3.1 is not any worse than the 3.8! As noted above, as long as you take care of the 3.1 motor, it's longevity is the same as the 3.8. Dexcool coolant is the suspected culprit for both motors and as long as you replace the Dexcool with the regular "green" antifreeze, these motors are bullet proof-both of them!
    I have 120,000 miles on 3.1 2001 GP and I replaced the dexcool at 60,000 miles-zero issues with either the LIM or the head gaskets! Have a neighbor with a 3.1 with over 200,000 miles on his 3.1-zero issues. Mechanic friend that routinely works on GM 3.8/3.1's states emphatically that the LIM/head gasket issues with the V6's is the same for both motors-he has done many on cars with dexcool and almost none on cars with green antifreeze as long as the Dexcool was replaced at fairly low mileage.
    The 3.1 is a great motor as is the 3.8 but the constant bashing of the 3.1 is just NOT true or warranted. I actually prefer the 3.1 over the previous three 3.8 V6 cars that I have had since my slightly modified 3.1 has the same power now (real world driving, not dynoed!) as the stock 3.8's that I owned with slightly better highway fuel economy and significantly better around town fuel economy.
  15. #15 Re: u bend delete
    new britain, ct
    nice to see some 3100 love for once hah.
    just a side question. does anyone know if the ubend delete they sell on milzy will fit a 95 with the 3100? i dont see why it shouldnt but id like some thoughts before i spend a couple hundred on one to find out it doesnt fit lol
    07 Black GXP.
  16. #16 Re: u bend delete
    yes, thank you
    No, there are plenty of people that care...it's just the rediculous claims I have seen that make me NOT want to give a damn...
    This.
    3100/3400's are notorious for top end problems.
    Nope!
    3100/3400 motors have head gasket issues...in which the 3800's don't.
    That's great...doesn't mean other people are so lucky...general maintence on ANY motor can make it run for a very long time...it isn't just the 3100.
    Yeah, real world...toss it on a dyno and see that it probably makes a solid 20 wheel HP less than a 3800.
    It is all about looks. However, IT IS DYNO proven, that any W-Body exhaust flows very well for stock...and anyone claiming power from a catback is crazy. People have actually dynoed and lost power from a catback...since the factory unit flows VERY well up to 350~FWHP. I'm not saying a catback can HURT really...but I wouldn't waste my money on more than a muffler to change the sound if that is what your going for.
    Quote Originally Posted by twich12 View Post
    Noted.
    But.
    You do realize stock 3800's knock even in N/A form from the factory correct? Which means pulled timing...and possibly even making less power than your car...sure...especially if yours is in good shape. I'd be willing to bet my custom tuned N/A 3800 with NO knock on the junk 91 I run in it everyday would put a hurtin' on any 3100 car on this forum.
    Here ya go...don't waste your money on a "dual exhaust"...really. If I had a 3100...
    I'd top swap it...3400/3500 Top End, Ported Throttle Body, Custom Tuned PCM, Milzy's PEM's, 3" Catless DP, TransGo Shift Kit, P&P'd heads with Milzy's Stage 2 Cam.
    I'd be willing to bet it'd get close to 200 WHP and run with a Full Bolt-Ons 3800's car...but then your at the point to where the 3800 has spent less than a grand and your a couple grand into yours...which at this point I would have just snailed the damn thing to begin with...like the 3400 Grand Am guys have...and make some pretty decent power.
    Quote Originally Posted by ctracer View Post
    Does anyone know if the ubend delete they sell on milzy will fit a 95 with the 3100? i dont see why it shouldnt but id like some thoughts before i spend a couple hundred on one to find out it doesnt fit lol
    Honestly...just take it to your local exhaust shop and toss it up on the lift and have them cut it out...along with your cat...because emissions are lame.
    Lastly...just for S&G's...I'd like to see you 3100 guys get to the track and get some times. Just to see how they compare to the 3800. That way there isn't anymore of this "3100 hate" crap going around.
  17. #17 Re: u bend delete
    St Thomas Ontario
    sorry i wasnt clear, but my impala has a 3800, the reason i want plog and downpipe is cause i want to turbo when i get all the bolt ons. but i heard i cant run headers with a turbo...correct?
  18. #18 Re: u bend delete
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    what do you meen by "snailed"????
  19. #19 Re: u bend delete
    Quote Originally Posted by bandits grand prix View Post
    turbo'd
  20. #20 Re: u bend delete
    ImageShack® - Online Photo and Video Hosting
  1. u bend delete
    By kking89 in forum General Tech Discussion
    Last Post: 05-18-2011, 06:05 PM
  2. U-Bend Delete
    Last Post: 04-18-2011, 06:02 PM
  3. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  4. u-bend delete
    By amwhitey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:39 PM
  5. U-Bend Delete?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 12:45 AM
