Thread: EGR system
Results 1 to 6 of 6
  1. #1 EGR system
    SE Level Member 3100sfi's Avatar
    Jul 2011
    Canada
    I have what I believe to be an exhaust leak under the hood and it did not look to be coming from the manifolds, but near the EGR valve.
    Seafoam is great for finding the general area of exhaust leaks!
    What comprises the EGR system in these 3100 sfi cars? The only experience I have is with early EFI Fords and their systems. valve>sensor>regulator and everything is internal to the manifolds/heads.
    From where do our EGR valves tap the exhaust?
    Where would you look first for leaks? Old gaskets?
    1996 Pontiac Grand Prix SE coupe - white - stock until something breaks
  2. #2 Re: EGR system
    Charles City, IA
    Follow the tube from the valve to the manifold and look for leaks.
    SMGPFC Two Nipple General
  3. #3 Re: EGR system
    Jul 2011
    Canada
    Is it just a pipe from the manifold to the electronically controlled valve? That's all there is to it?
  4. #4 Re: EGR system
    yea thats basicly it, more then likey its leaking from either sides of the pipe, like stated before
    SMGPFC Member #10
  5. #5 Re: EGR system
    Jul 2011
    Canada
    It's been raining so I haven't gone out to check anything. ****in' pipe looks to be pretty expensive though!
    Hopefully it's just a gasket, but if not, a few spots of weld ought to seal up the pipe should it have any leaks.
    Thanks fellas. Much appreciated.
  6. #6 Re: EGR system
    Grand Island, Nebraska
    theres no gaskets...just get some red RTV.
  1. got the system in the gtp
    By sven101 in forum Audio, Security & Visual Electronics
    Last Post: 11-19-2010, 11:22 AM
  2. Abs system
    By doubled in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2010, 09:28 PM
  3. New System help
    By 0LmtdGP3800 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 09:52 PM
  4. My system
    By durag14 in forum Audio, Security & Visual Electronics
    Last Post: 03-12-2009, 08:25 AM
  5. Looking for a pa system
    Last Post: 01-29-2009, 11:42 AM
