Thread: CAI question?
Results 1 to 11 of 11
  1. #1 CAI question?
    ok i have a quick question about a CAI i made,
    ok so heres a little back ground as most ppl know the 3.1(3.4) have a external MAF sensor so ive had find out a way to make one work,,,alright got all that taken care of and now ive been tring to hook the other things up, the IAT and a vacuum tube, ive drilled a hole for the IAT and was bout to do the same thing for the tube, but thats were i ran into a problem, the tube im using to connect the MAF to the thottle body to to short for me to drill a hole in, so i came up with an idea to take to tube and cut it, then take a hose and connect the twos halfs, basicly just making it longer so i can put it up closer to the filter, so now on to my question, is there any reason my the tube was placed behind the MAF, i want to put it infront of the MAF so i wanted to check to see if i would mess something up, but why put it behind the MAF in the frist place, if it takes air away before it enters the thottle body, does that mean that ther is less air intering the motor then the MAF reads, idk im lost, oh and fyi i think the tube is for the PCV system
    heres a pic of the tube im taking about, this is not my current set up but its the only pic i have atm
    any tips and .2cents are welcome
    SMGPFC Member #10
  2. #2 Re: CAI question?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    my engine is a 3.8 but the tube you are talking about is after the maf.
  3. #3 Re: CAI question?
    i know thats why im asking if it can be moved so its infront of the MAF
    SMGPFC Member #10
  4. #4 Re: CAI question?
    Nov 2009
    IIRC no.
  5. #5 Re: CAI question?
    thats not what i wanted to hear,,
    anyone else have something to say
    SMGPFC Member #10
  6. #6 Re: CAI question?
  7. #7 Re: CAI question?
    GT Level Member neel2008's Avatar
    Huntington, IN
    x2 ^^^
    97gtp
  8. #8 Re: CAI question?
    It's a 3.1...it needs all the help it can get?
  9. #9 Re: CAI question?
    but being before or after the MAF shouldnt make a lick of difference. so long as it's there somewhere it should be fine.
  10. #10 Re: CAI question?
    Zip tie it to the headlight.
  11. #11 Re: CAI question?
    why does it matter where the IAT is?
    i dont think it does, but the vacuum tube is what im worried about moveing
    i know right, im gonna start running a NO2 bottle full of hopes and dreams in the fall
    ok thanks thats what i was thinking
    SMGPFC Member #10
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
