Thread: I think my oil pump broke...hope motor is ok
Results 1 to 9 of 9
  1. #1 I think my oil pump broke...hope motor is ok
    SE Level Member wingman65's Avatar
    Dec 2010
    Missouri
    New member here, long time GP owner. My 95 SE 3100 won't turn over now. Driving home from work, oil light came on and engine started running rough, then stalled. I got it to start and nursed it off road onto parking lot but it was really running rough and then died. Towed it home, now it wont turn over
    Anyone have any ideas. I hope it isnt fatal.
    Tony
  2. #2 Re: I think my oil pump broke...hope motor is ok
    Once the oil light comes on you're done generally.
  3. #3 Re: I think my oil pump broke...hope motor is ok
    you probably spun a bearing. my bet is that it wont start and if it does it knocks at idle.
  4. #4 Re: I think my oil pump broke...hope motor is ok
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    uh oh..... im affraid of my engine...
    how many miles do you have on it?
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  5. #5 Re: I think my oil pump broke...hope motor is ok
    Dec 2010
    Missouri
    140k and ran great til yesterday. I just replaced the lower intake gasket a couple of months ago and that fixed my leaks. Should I attempt replacing the crank, bearings and oil pump or should I plan on a motor replacement. Money is tight but I cannot go without a car or buy a new one.
    Tony
  6. #6 Re: I think my oil pump broke...hope motor is ok
    if you take apart the bottom end you need to get things machined. easiest thing to do is to drop in a new block.
  7. #7 Re: I think my oil pump broke...hope motor is ok
    Dec 2010
    Missouri
    Is it possible to pull the motor while leaving transaxle in place?
  8. #8 Re: I think my oil pump broke...hope motor is ok
    Grand Rapids, MI
    veyr possible. on my 97-03 (assuming they are similar enough) you just take out the bell housing bolts and flywheel /torque converter bolts and the engine comes out.
  9. #9 Re: I think my oil pump broke...hope motor is ok
    Dec 2010
    Missouri
    Update to my motors health. It has a broken cam, bent valve, and a spun rod bearing that had welded itself to the crank. The motor was locked up tight, making it difficult to get to torque converter bolts. I wound up pulling it away from trans about an inch and getting to the bolts with a long, thin 18mm wrench.
    Bought a used 3100 from "flea bay" believe it or not for $700 delivered. Went through it giving it a very thorough inspection, replacing all the gaskets and cleaning it inside and out. No sighns of sludge, very clean on inside.
    Today I got it bolted back into car along with a new solid rubber lower mount. I need to reinstall accessories and electronics and all will be golden. Thanks a bunch to all on this forum for the vast collection of information, It was priceless.
  1. hello to the forum, I hope you can help me!
    By 787heavy in forum Introductions/Noob Questions
    Last Post: 04-27-2009, 03:34 PM
  2. :( no hope
    By LogicGTP in forum Track Sessions and Kills
    Last Post: 02-18-2009, 04:52 PM
  3. Windshield Wiper Pump Broke again.....
    By Egleone6 in forum General Tech Discussion
    Last Post: 11-28-2008, 05:23 PM
  4. Very bad night, broke motor mount
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 09:15 PM
