My 94 Grand Prix has an intermittent issue with not wanting to turn over to start.
When you turn the key you can hear it click at the starter but it will not engauge the starter.
I have a new battery and also replaced the starter and it still does the same thing.
I removed and re-grounded the ground wires under the hood and still the same. I also removed the switch on the steering shaft that the rod works in and out from the key switch. opened it up and checked all of the contacts and put it back together and still the same thing.
My keys have a security chip and I have tried both keys and still the same. Voltage is good.
Neutral safety switch going bad???
I have a relay for an anti-theft security switch that I got from NAPA but I have not found this on my car. Mine might not have this relay. The manual is showing an Anti-theft fuse which would only work or not and wouldn't be intermittent.
I'm hoping it's not the key switch because of the security. I'm really puzzled that if it's the key switch why would it click like it's trying to start.
When it does start, in some cases, it seems to have a short delay before it cranks.
This is a tough one to track down. I build race cars on the side and I hate it when a problem like this is occuring.
Has anyone had anything like this happen with their Pontiac???
AMXTRA
