so, i had my car for 5 yrs since it has 180k miles i had it ive replace the transmission around 120k due to a bad solenoid , change the water pump, starter, altenator, o2 sensor, all 6 coils, harmonic balencer, and remove and replace the intake manifold gaskets, great car but ive had to many thing wrong with it.
anyhow i just got it working again, nothing was wrong with it just had to pay some fines.
now that its running its vibrating a lot when idle and pulls on the fwy and streets here and there
just replace all 6 spark plugs and wires.
it turn on for a few sec (2-5 sec) then turn off again
my obd scanner says its has 3 codes
P0131 which has to do with the o2 sensor
p0336 which is the crankshaft position sensor
p1811 (max adopt and long shift) don't know what that is except that it has something to do with the transmission.
i just want some input do i need a special tool before i replace the crankshaft position sensor and where exactly is it? and what exactly is P1811? oh and any-help with the vibrating- although i think its the harmonic balanced.
thanks
