Thread: GP 1994 & 1995 Scanner
Results 1 to 8 of 8
  1. #1 GP 1994 & 1995 Scanner
    Jan 2009
    On This Planet...
    Hi!
    doe`s anyone knows what scanner fits my cars? (except GM Tech 1...)
    i found that the innova 3140 can read OBD I (and II) but GP 94-95 doesn't mentioned in the user manual.
    i also checked the AutoXray EZ-Scan AX6000 and 7000. they can read OBD I (and II) but no cars excluded in the user manual, so i can`t tell for sure.
    i sent query about this matter to the makers, but none of the company's above returned me an answer...
    any ideas?
  2. #2 Re: GP 1994 & 1995 Scanner
    You are probably an obd 1.5 based on the years you listed. Check the actron 9145. IIRC it'll do both, but you might need a different cable for it.
  3. #3 Re: GP 1994 & 1995 Scanner
    Jan 2009
    On This Planet...
    thanks!
    i`m looking at the actron products right now...
    the actron 9190 kit looks pretty good. but the big question is can it read the gp aldl dtc`s correctly?
  4. #4 Re: GP 1994 & 1995 Scanner
    If it says it'll read the 92-93 era, then yes. The thing (at least on Bonnies) in 95 was that it was a mix of plugs and codes one is obd 1 and the other is obd2. Damn hybrid year.
  5. #5 Re: GP 1994 & 1995 Scanner
    Jan 2009
    On This Planet...
    Damn hybrid year.
    yeah! you got that right...
    my gp`s have a 12 ALDL connector. how can i tell if the protocol is obd 1 or 2?
    (or 1.5???) and if the actron scanners can work just fine?
  6. #6 Re: GP 1994 & 1995 Scanner
    You'd have to have trouble scanning to know about the protocol. I'm not familiar with the GP's in those years, but the Bonnie's were the hybrid. Got the OBD 1 connector, OBD2 codes and I think it was still technically running the OBD1 programming.
  7. #7 Re: GP 1994 & 1995 Scanner
    Jan 2009
    On This Planet...
    thanks!
    the last time an authorized GM mechanic scanned the dtc`s, he used the GM Tech 1 scanner.
    does it specify the protocol? (obd 1 or 2?)
    i`m so frustrated from this issue...
    by the way, does anyone knows if the Equus 3140 Innova Diagnostic Code Scanner for OBDI and OBDII Vehicles is compatible with gp 1994 & 1995? the scanner looks so cool...
  8. #8 Re: GP 1994 & 1995 Scanner
    Apr 2012
    Central Florida
    Quote Originally Posted by Viper View Post
    Hi!
    any ideas?
    if you are still looking for a Scanner for your vehicle I just purchased an Actron CP9145 Super Autoscanner and it should work on your car .... I also own a 1994 Pontiac Grand Prix
  1. will a 1995 2 door bumper cover fit a 1995 4 door?
    By pjgilboy in forum Introductions/Noob Questions
    Last Post: 12-11-2009, 12:45 PM
  2. 1994 Gp
    By Orbital431 in forum Visual/Body Modifications
    Last Post: 09-10-2009, 08:10 PM
  3. 1994 Grand Prixer here
    By jokyfo in forum Introductions/Noob Questions
    Last Post: 10-09-2008, 11:32 PM
  4. killed a 1994 grand am
    By zach_gt in forum Track Sessions and Kills
    Last Post: 06-04-2008, 07:19 AM
  5. 1994 CTS Problems
    By dave1994 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-30-2008, 02:04 PM
