Thread: Cooling Fans Not Working
Results 1 to 15 of 15
  1. #1 Cooling Fans Not Working
    Nov 2009
    WA
    We just got this 96 GP running today (engine swap runs great) but it has some electrical issues. Relays check fine. The fans work if you do the relay paperclip trick. It has a new coolant temp switch. Also the air conditioner is not engaging the clutch, no current through the harness. The ECM isn't providing a necessary ground to the relays to kick the fans on.
    I was careful on marking every harness connection, I'm really puzzled. What's wrong with this thing?
  2. #2 Re: Cooling Fans Not Working
    Nov 2009
    WA
    I installed a toggle switch to the relay. Ebay had a good used ECM so we will give that a try.
  3. #3 Re: Cooling Fans Not Working
    SE Level Member musiknjoyr's Avatar
    Feb 2009
    decatur, al
    just replace the relay. sometimes they just act completely stupid. autozone, lifetime warranty and like 15 bucks
  4. #4 Re: Cooling Fans Not Working
    SE Level Member tnt7982's Avatar
    Sorrento FL
    I was reading this post and have the same issue with my 95 3.1L SE . Did you ever fix it ? I was thinking a low pressure switch for the A/C but I can't seem to find one. Well any help would be greatly Appreciated.
  5. #5 Re: Cooling Fans Not Working
    Nov 2009
    WA
    I purchased an adjustable switch that I installed to the relay. This provides a ground to trigger the relay. Flex A Lite was the brand. I know this is not the correct solution to fixing the problem but I have other things I have to get done. I will figure it out later. Oh I installed a different ECM that made no difference.
    If you figure your problem out please let me know. Thanks.........Chuck
  6. #6 Re: Cooling Fans Not Working
    Jan 2009
    On This Planet...
    try checking legs number 85 & 86 on the box (not on the relay) if they got 12V when the engine is hot. (one of them is ground and the other is 12V, so you can check it with a multimeter to find which is grounded and which is connected to the computer).
    if you don`t get the 12V on none of them, or one of them isn`t grounded, check the wires all the way from the box for electrical continuity.
    let us know what you find.
    p.s.
    here`s a typical relay layout: http://www.rowand.net/shop/tech/imag...iringGuide.jpg
  7. #7 Re: Cooling Fans Not Working
    GT Level Member 91gpse's Avatar
    warren, mi
    sounds like a bad ground.... your best bet is to look for a wiring diagram and find out where the ground is.
  8. #8 Re: Cooling Fans Not Working
    Sorrento FL
    Viper you are the man and thanks to 91 also. Low and behold it was a bad ground !!!!! Dude she is working like a champ thanks guys !
  9. #9 Re: Cooling Fans Not Working
    Jan 2009
    On This Planet...
    your`e welcome!
    happy that you fixed the problem.
  10. #10 Re: Cooling Fans Not Working
    warren, mi
    Quote Originally Posted by tnt7982 View Post
    no problem... had the same issue with my old beretta.
  11. #11 Re: Cooling Fans Not Working
    Lancaster,WI
    Hey Viper got a question It seems you know a lot about cars. Is it possible to replace a center console out of a car that has a hand brake spot in the center console?
    96 Grand Prix
  12. #12 Re: Cooling Fans Not Working
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by 96GrandPrix View Post
    I saw somewhere that a guy used a gran am center console,theirs has the hand brake. I did'nt fully understand yer question bro.
    1.Are you trying to add a hand brake?
  13. #13 Re: Cooling Fans Not Working
    Lancaster,WI
    I am remounting my e brake
    96 Grand Prix
  14. #14 Re: Cooling Fans Not Working
    warren, mi
    You can but its alot of work. Post a thread on it asking how to do it. This isnt exactly the place, go to the brakes section and ask how to relocate it.
  15. #15 Re: Cooling Fans Not Working
    SE Level Member 3100sfi's Avatar
    Jul 2011
    Canada
    At what temperature do the fans normally activate?
    1996 Pontiac Grand Prix SE coupe - white - stock until something breaks
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. 1994 gtp cooling fans not working
    By almighty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-01-2010, 09:39 AM
  3. PCM 180 thermostat Fans not working right
    By 04intimidatorSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2010, 11:52 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
