Thread: 91 gpse ,throttle is sticking
Results 1 to 3 of 3
  1. #1 91 gpse ,throttle is sticking
    Jul 2010
    parma ohio
    My gp is sputtering in park, then when i kick it in drive the rpms stick at 2k.Then when i come to a stop, its still racing and then kicks down to a sputter.The code reads, heated oxygen sensor (HO2S) circuit (rich exhaust indicated).Any tips on this problem will help ,thank you.
  2. #2 Re: 91 gpse ,throttle is sticking
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    It sounds like your throttle position sensor (TPS) might be shot, or dirty. I'd first start with spraying the throttle body and TPS clean first. If it still has the problem, try swapping the TPS out. They're only about $15 new.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  3. #3 Re: 91 gpse ,throttle is sticking
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sound like there may be more than one issue. check all vacuum lines. check wiring for the 02 just some thing to try ...
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. sticking door handles
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-01-2010, 01:22 PM
  2. 96 GPSE 3100 spitting,sputtering,and backfiring
    By 96gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2009, 09:46 PM
  3. Help With Sticking Sun Roof
    By Zilcho in forum General Tech Discussion
    Last Post: 08-21-2009, 06:06 PM
  4. Sunroof Sticking
    By streetsmart in forum General Tech Discussion
    Last Post: 06-27-2009, 01:04 PM
  5. Gas Pedal Sticking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-29-2008, 09:53 PM
