Thread: running hot ??
Results 1 to 4 of 4
  1. #1 running hot ??
    SE Level Member rickchall69's Avatar
    Feb 2009
    wisconsin rapids, wisconsin
    I have a 95 grand prix se 3.1. Not sure what is going on. To start of, it has new water pump. Run the car for the first time for the day the temp will climb to 220 maybe a little more, drop down to about 200 210 and when you get on it climb back up to 220 225. the motor doesnt act like its getting hot. Maybe temp senor going haywire. Temp gauge never stays at one temp for long. Any ideas?
  2. #2 Re: running hot ??
    Jul 2008
    i had a problem with my 96 3.1L overheating turned out to be intake manifold gasket problem, the radiator fluid was leaking there and needed to be replaced. dunno if its related, something to think about
  3. #3 Re: running hot ??
    Feb 2009
    Mass
    I had the exact same problem as you. I just added new coolant and the problem was solved. I will do a whole flush when I get the time but just try adding like 1/2 a gallon of coolant and 3/8 gallon of water. Don't worry about overfilling it. It will just leak out if it gets too high.
  4. #4 Re: running hot ??
    SE Level Member musiknjoyr's Avatar
    Feb 2009
    decatur, al
    lower intake gasket
  1. Running wires for an Amp and Sub
    By y1a3o in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2009, 08:28 PM
  2. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
  3. Won't start after running out of gas
    By DesQ27 in forum General Tech Discussion
    Last Post: 02-13-2009, 07:59 PM
  4. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
  5. Is anyone running these tires (255/45/18)?
    By fatride99 in forum Tires & Wheels
    Last Post: 07-11-2008, 12:20 PM
