Thread: Any probs. with '94 3.1?
Results 1 to 10 of 10
  1. #1 Any probs. with '94 3.1?
    Iowa
    I am in the process of getting a '94 3.1 for my '88 Grand Prix. I was just wondering if there were any problems with the 3.1 motors that I need to know about before I swap it in?
    1988 Grand Prix coupe (base): Custom two-tone paint - blue/gray - recently quit at 249,092 miles!
    1999 Ford Explorer - daily driver, stock..... for now!
  2. #2 Re: Any probs. with '94 3.1?
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    The only real downfall to the 3100/3400 motor was GM's retarded idea of using nylon/silicone for the intake gaskets, which were inevitably prone to failure. When the LIM gasket goes, depending on how bad the sepage is into the block, it can either lock up the motor, or the coolant destroys the bearings, leading to a spun bearing.
    The other issue is the '94 uses an OBD 1.5 (an OBDI/II hybrid), where as your '88 is an OBDI. This might be a wiring nightmare for the swap. I'm not positive on whether you'd need to change wiring, the computer, etc.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  3. #3 Re: Any probs. with '94 3.1?
    I'd just try to find something pre-'93 IMO...that way it is a direct swap.
    Also...just change all the gaskets while the motor is out
  4. #4 Re: Any probs. with '94 3.1?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    and what engine is in the 88 prix now? the 2.8? and you are going to the 3100? or pre 94 3.1? even if it is a more direct swap from a 93 and less for a 3.1 dont you have to change the prom chip in the pcm?
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  5. #5 Re: Any probs. with '94 3.1?
    Dec 2008
    Naperville, IL
    It's the 2.8L. The only GM to get the 3.1 in '88 was the very limited (124 made) Pontiac 6000 STE All Wheel Drive. And if it's truly a '94 he's picking up, it would have to be the 3100. Changing PROM chips is a breeze. It's changing out all the wiring and computer that would be a serious pain in the ass. If he's going to go through all that, he'd be better off getting a '00 & up 3400, and swapping over to an OBDII computer. More power to start with, plus a lot more easy to tune.
  6. #6 Re: Any probs. with '94 3.1?
    Iowa
    I actually just bought a '00 3100 last week. I have talked it over with guys on the 660 forum, and I don't have to do a whole lot to do this swap.
    I can run the 2.8's ECM, injectors, and motormounts. That way it will be a lot easier to deal with.
  7. #7 Re: Any probs. with '94 3.1?
    Those 60* guys know their stuff...good deal you got it all figured out man!!
  8. #8 Re: Any probs. with '94 3.1?
    Iowa
    Thanks, I hope so! I just got the new motor unloaded from my dads S10 last night, and I hope to start disassembly of the 2.8 tomorrow.
  9. #9 Re: Any probs. with '94 3.1?
    Iowa
    Here are some pictures of my car and engine. Any constructive comments or suggestions will be accepted. Thanks!
  10. #10 Re: Any probs. with '94 3.1?
    Iowa
    Some of you may have noticed that I may be missing some parts. I want to let you know that I do have all the parts.
  1. yeh i have probs
    By izup69 in forum 04+ Specifics
    Last Post: 09-11-2009, 11:19 AM
  2. New Here- 99 GTP Probs- need help- thanks
    By Juxtaghost in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 12:27 AM
  3. trans probs
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 05:10 PM
  4. Just got a 98 GTP, a few probs
    By somewhereinks in forum General Tech Discussion
    Last Post: 08-25-2009, 07:48 PM
  5. A/C probs
    By 2000segp in forum General Tech Discussion
    Last Post: 06-13-2008, 07:09 AM
