Thread: Help With My '93
Results 1 to 20 of 29
  1. #1 Help With My '93
    SE Level Member steveprix93's Avatar
    LOOGOOTEE, IN
    I need some help please... I bought a 1993 Grand Prix with a 3.1. with a major problem. I got it to drive back and forth to work because I heard they were reliable. I've had it for a few months now and then this started happening. If I'm driving down the road it sputters, the tach jumps around alot and it dies. I thought it was the crank sensor so that's where I started. it didn't fix the problem. So I thought I'd try plugs and wires, that didn't help either. I took my coil packs and ign. mod. in to get them tested and they tested fine. My battery was weak, so I replaced my battery and the neg. battery cable because it was frayed. Next was the fuel filter that didn't fix the problem either. I took it to the local GM dealership and they couldn't track down the problem. I'm running out of options at this point. Is it the computer? Is there any way to test it? Any other suggestions? I have been screwing with this for a month and I don't know what to do with it
  2. #2 Re: Help With My '93
    Saraland Alabama
    computer is possible, only good test is a swap test (same with module the testers don't work never have) do you get a check engine light? Can you flash the codes (should get a code 12 first if not the computer is bad)
  3. #3 Re: Help With My '93
    LOOGOOTEE, IN
    The engine light isn't on, and when we tried to pull the codes nothing showed up.
  4. #4 Re: Help With My '93
    Feb 2008
    West Virginia
    coil packs and the icm, my '92 did the same thing and new coilpacks and new icm fixed it and hasnt happened since
    Dan Johnston
    1992 Grand Prix SE 3.1L
  5. #5 Re: Help With My '93
    Feb 2008
    West Virginia
    I took mine to a dealer to check my icm and coils too, they said they were fine, but they were bad, if you can try swapping out each coilpack with a different one if you have one lying around and see if that helps
    Dan Johnston
  6. #6 Re: Help With My '93
    LOOGOOTEE, IN
    Will all three coil packs go out at the same time or will one coil pack cause this problem?
  7. #7 Re: Help With My '93
    Feb 2008
    West Virginia
    Not likely, but I didnt want to take the time to determine which one was bad so I replaced the whole thing..After I looked at the old ones it looked like one of the coils was original (still had the number markings), and the other two had been replaced at some point.
    Dan Johnston
  8. #8 Re: Help With My '93
    LOOGOOTEE, IN
    Does it sound more like a computer problem or the coil packs and ignition module? Niether one is cheap so I'd hate to do the wrong one.
  9. #9 Re: Help With My '93
    Saraland Alabama
    see about some used ones, the coil packs with icm sell for about $30 then if that fixes it buy the new ones
  10. #10 Re: Help With My '93
    LOOGOOTEE, IN
    Where can I get some used ones? Anyone have some sitting around that they want to sell?
  11. #11 Re: Help With My '93
    Feb 2008
    West Virginia
    local junkyard would be your best bet, Ill try to look tomorrow and see if I have my old ones lying around for ya
    Dan Johnston
  12. #12 Re: Help With My '93
    Banned
    New Port Richey Florida
    I have a set coils and icm here thats known good i changed them cause i thought i had a bad plug i'l let them go for what the local yard does 50 +shipping
  13. #13 Re: Help With My '93
    Saraland Alabama
    check out car-part.com I got mine shipped to me for $25
  14. #14 Re: Help With My '93
    LOOGOOTEE, IN
    What kind of a price am I looking at for a new computer and where should I get one?
  15. #15 Re: Help With My '93
    Saraland Alabama
    new will be about $150-$200 I think, most auto parts stores sell them
  16. #16 Re: Help With My '93
    LOOGOOTEE, IN
    Will I have to get it programmed or will I be able to plug it in and that's it? I was told that I would have to tow it to the dealership to get it programmed after a installed the new computer.
  17. #17 Re: Help With My '93
    Saraland Alabama
    take the computer to oreilleys and they program them out of the car
  18. #18 Re: Help With My '93
    LOOGOOTEE, IN
    Well I replaced the ECM and that didn't solve my problem... I'm going to replace the Ignition mod. and coil packs next. I got on autozones website and where they show the crank sensor isn't where mine was at. I replaced the one on the back of the motor above the transmission but they show it under the harmonic balancer. Are there 2 of them?
  19. #19 Re: Help With My '93
    Feb 2008
    West Virginia
    as far as I know there is only one of them
    Dan Johnston
  20. #20 Re: Help With My '93
    Saraland Alabama
    only one I know is behind the balancer
