Thread: 96 GPSE 3100 spitting,sputtering,and backfiring
Results 1 to 4 of 4
  1. #1 96 GPSE 3100 spitting,sputtering,and backfiring
    SE Level Member 96gpse's Avatar
    Feb 2009
    Hopkinsville, Kentucky
    I've had my GP since october and other that my Rad Fans not working i've not had any problem til now , my girlfriend drove the car yesterday and as she was leaving the college it died a few times but started back up, then this morning i drove the car and it did fine til after work but started spitting almost like it was cutting out , never did die on me but when you rev the motor up to about 2500 and let off you can hear a sound that sounds like backfiring in the exhaust. could this be a crankshaft sensor problem or fuel filter, or something more?
  2. #2 Re: 96 GPSE 3100 spitting,sputtering,and backfiring
    GT Level Member tylerbinski's Avatar
    Canada
    OP?
    did u figure this out
  3. #3 Re: 96 GPSE 3100 spitting,sputtering,and backfiring
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sounds like the classic crank sensor wire is melted somewhere and is grounding. i did a rebuild on a 95 se and the thing ran good except for the knock, well when i had the engine out the crank sensor to ignition module wire was bare in spots, so i repaired it, but i actually seen a 93 se short out, bckfire, spit and sputter. sometimes it would run fine. i changed everything.....finally i kept saying it had to be a wire problem, so i went and got a used crank sensor wire(i chose the best one i could find) no oil on it etc.....got his old one off and upon inspection, yes there it was both wires were bare in almost the exact same spot...they were grounding out, car been running for over a year and hasnt stalled once! good luck let us know.
  4. #4 Re: 96 GPSE 3100 spitting,sputtering,and backfiring
    Rayle, Georgia
    96gpse
    I had the same problem. I put my OBDII scanner and it told me that it was my MAF sensor and Throttle control sensor. I let it ran for about 15 minutes and the problem stopped; and hasn't happened again...knock on wood..
  1. 3100 mods?
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2012, 08:41 PM
  2. sputtering problem
    By Risinnfallen in forum General Tech Discussion
    Last Post: 01-07-2011, 06:00 PM
  3. sputtering in the upper rpms?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-06-2008, 04:36 AM
  4. backfiring when i let off the gas
    By shawn in forum General Tech Discussion
    Last Post: 08-08-2008, 11:46 PM
  5. backfiring when i let off the gas
    Last Post: 08-08-2008, 08:48 PM
