Thread: Car boggs, wants to die when giving gas.
Results 1 to 15 of 15
  1. #1 Car boggs, wants to die when giving gas.
    North Carolina
    Hello, I have a 1990 model with only 100,000 original miles. The previous owner took pretty good care of it. It was running great untill about two weeks ago. It idles fine, and drives if you barely give it gas. Once you step on the gas, it boggs down, and barely goes. It even bogged, and cut off once. I have changed the
    Fuel injectors
    fuel pump
    fuel filter
    maf sensor
    air filter
    oil, oil filter
    and idle air control. I checked the fuel pressure, and it was normal. The coil pack was also changed before I got it. I took it to someone to read the codes, and he said he didn't get any? My brother said he checked the comp and fuses, and that was all fine. The only thing I can think to check is for a vacuum leak. What do you guys think? Thanks.
  2. #2 Re: Car boggs, wants to die when giving gas.
    Oct 2008
    mascoutah, Il
    I'm sure others will chime in eventually with other ideas, but I would definitely check your vacuum lines. I'll try to help...im not familiar with the 3.1s as I am with the obd2 3100s.
    Are you getting any knock/pinging? Maybe you got some bad gas?
    I'm not sure if the symptoms match a stuck EGR or not. But I would think that would throw a code.
    Maybe a clogged cat?
    for more info try 60degreev6.com
    let us know what you find!
    2002 GTP
    custom HOK paint
  3. #3 Re: Car boggs, wants to die when giving gas.
    North Carolina
    Thanks for the reply. I changed out the gas, when I put in the new pump. Also used high grade. I couldn't find a vacuum leak, so i'm gonna test the cats pressure next. I hate thinking about how much i'll get charged, for someone to wield a new one in.
  4. #4 Re: Car boggs, wants to die when giving gas.
    ocala
    hey have you fixed this car yet? i just got one that does the same thing and need help fixing. it seems like no throttle responce but i changed out the TPS, fuel pump, filter, and pressure reg. it will rev up about the first 30sec but then the problem starts.
  5. #5 Re: Car boggs, wants to die when giving gas.
    North Carolina
    Not yet. No vacuum leak, and the cat checked out. Maybe a broken wire or grounding prob somewhere? A GM mech is gonna look at it this week, I'll let you know what he finds.
  6. #6 Re: Car boggs, wants to die when giving gas.
    Minnesota
    Hey, I have been dealing with a similar problem for two and a half years and fixed mine just last night.
    The problem was the upstream O2 sensor. I have a newer 3.1 but I believe they are set up very similar. There is an upstream and a downstream O2 sensor, one before and one after the catalytic converter. The one downstream, after the converter, is just for emissions purposes. The upstream effects how the car runs by detecting the amount of oxygen in the exhaust gases and adjusting for peak performance and fuel economy. The best way to test it would be to just unplug the sensor and drive the car to see if it runs differently, it will either run the same or it may even run better if it is bad. The reason for it running better would be due to the computer switching over to a loop cycle or rich cycle because of it detecting there being a problem with the sensor. The sensor is located behind the engine, about in the center, tapped into the exhaust manifold. For me it was easier to go from the top of the engine, but the sensor has 3 or 4 wires coming out of it with a clip that plugs into the wire harness. My clip was kind of a bugger to unhook and be careful not to rip the wires out, but just unclip it and tuck the clip somewhere so you do not melt it on the exhaust manifold when you drive it.
    Let me know if this helps.
  7. #7 Re: Car boggs, wants to die when giving gas.
    Feb 2008
    I've experienced quite a few bad o2 sensors that didn't throw any codes, so it's very likely that can be your problem. Hopefully you find the issue.
  8. #8 Re: Car boggs, wants to die when giving gas.
    ocala
    ok so checked and this gp has a single wire o2 so that wasnt it. now i went and got another memory chip and installed it and it runs fine.
    now the problem sounded the same as yours so i would sugguest you try the same. got this one out of the comp of another gp. its inside the cover thats held on with 4 little bolts. good luck and thanks for the help.
  9. #9 Re: Car boggs, wants to die when giving gas.
    Feb 2008
    Quote Originally Posted by prostreetjeep View Post
    Single-wire o2's can still be faulty and cause pretty significant running issues.
    I'm glad to hear that you fixed your issue, though. Maybe the OP can try either or both solutions.
  10. #10 Re: Car boggs, wants to die when giving gas.
    ocala
    yes i agree. something did spike past the parameters to burn up the chip. that does need to be fixed so it does not happen again.
  11. #11 Re: Car boggs, wants to die when giving gas.
    North Carolina
    Unplugged the 02, and it was the same. A friend of mine said he would wield a new cat in for me, that his car did the same thing. If thats not it, i'll look at the chip. I'll keep you guys updated.
  12. #12 Re: Car boggs, wants to die when giving gas.
    North Carolina
    Gonna replace my Cat in the morning. I will cry if this doesn't fix it lol. I'll let you guys know what happens.
  13. #13 Re: Car boggs, wants to die when giving gas.
    North Carolina
    Ok, changed the cat, and that wasn't it. I did find two hidden vacuum leaks and fixed those. It runs better, but still boggs/wants to cut off. Now we are looking for any other vacuum leaks, or a broken wire. There has got to be something we don't see.
  1. Car wont fully start without giving it gas... wtf
    By Piggy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-15-2009, 05:41 PM
  2. car is giving me 5 codes
    By 97gp97 in forum General Tech Discussion
    Last Post: 03-31-2009, 12:56 AM
  3. car is giving me 5 codes
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2009, 04:50 PM
  4. Giving Thanks
    By SyntheticShield in forum Site/Club News
    Last Post: 09-11-2008, 03:49 AM
