Thread: Over heating?
Results 1 to 15 of 15
  1. #1 Over heating?
    GT Level Member bkaab's Avatar
    Adrian MI
    My car today after about 13 min of driving said that the temp was 260! What is up with this its not even hot out. First 6 min was at 75mph and then I drove through a car lot stopped looked at 4 cars and then left and the rest of the way home I was doing 40mph. When I got home it was hot fans full blast and all. What would cause this like I said its not even hot out here.
    '01 GP GT Topswap GT
    '95 GP GTP 3.4DOHC V6
    '95 GP SE Gone but not forgotten.
  2. #2 Re: Over heating?
    Hoffman/Schaumburg, IL
    could be a thermostat stuck closed, when the car is at 260. check the radiator hoses, the top one particularly, you must be careful though this may be super -hot, also check the radiator, but same warning about temp..
    If both are only luke warm, like 85 - 115 degrees the thermostat is most likely stuck closed
  3. #3 Re: Over heating?
    PA
    Simple things first. Make sure your coolant is full.
    2001 GSE
  4. #4 Re: Over heating?
    Saraland Alabama
    and no air in the system. When was the last time the t stat was changed? If it's been a while go ahead and replace it (they are under $10 usually)
  5. #5 Re: Over heating?
    Adrian MI
    It has a blown head gasket or intake gasket. The coolant is all in the oil. I took it to a shop to day and they said it will cost 500$ or 900$. I will be getting her back all fixed by the end of the week.
  6. #6 Re: Over heating?
    Yeah, LIM gasket had it go on my old 3.1, $40 part, burried all the way at the center of the motor, ive changed the one in my moms van so many times I've got it down to under 4 hrs
  7. #7 Re: Over heating?
    PA
    Yes, the 3.1 and 3.4s are known for their LIM gaskets going, just as much as the 3.8 are. I did one on my wife's malibu. Not a hard job. Just takes time. My first time it took me about 8 hours. But I take my time and work slow.
    2001 GSE
  8. #8 Re: Over heating?
    my first try took 4 weeks(1.5 hours per day at school) and had to be torn down right away, because the new one leaked
  9. #9 Re: Over heating?
    Feb 2008
    Goodyear, AZ
    Quote Originally Posted by bkaab View Post
    this same thing happen to mine and it cost around 8XX.XX
  10. #10 Re: Over heating?
    Feb 2008
    West Virginia
    my '00 se had the LIM gasket went last fall, around 7xx, I wish I would have had the time to fix it myself but school had just started...
    Dan Johnston
    1992 Grand Prix SE 3.1L
  11. #11 Re: Over heating?
    Banned
    New Port Richey Florida
    Awww man that sucks dude and the 3100's and 3400's are prone for this not the 3.4 thats a whole different ball game right there with that engine. I hope you caught it in time to save the engine bearings.
  12. #12 Re: Over heating?
    Adrian MI
    They said at the shop all is good with it now. The fixed it and said it ran great.
    Now I owe my parents 550 bucks.
  13. #13 Re: Over heating?
    Oklahoma
    I would highly HIGHLY recommend you change your oil out as soon as possible even if it was done at the shop. The reason for this is that coolant is very persistent inside a motor. That is to say that it hides in places, adheres to things and could still be in enough volume to cause issues if not flushed out. Doing a couple quick oil changes will greatly reduce any risk from any remaining contamination.
    Do one as soon as you get it home, then maybe another in 500 miles or so. Im kinda anal about this since Ive seen from oil analysis how long coolant can persist in an engine so others may have different recommendations that I would take into account as well.
  14. #14 Re: Over heating?
    Fort Wayne,IN
    I agree with Scotty even though a shop says its all good it's better to be safe than sorry. Change the oil and filter just like Scotty said and just watch the temps and check your oil to make sure it's all out. It's cheaper to take pre-cautions than to buy a new motor.
    A.K.A. Trannyman's Wife
    www.tripleedgeperformance.com
  15. #15 Re: Over heating?
    Adrian MI
    Ya I am going to change it in 100 miles which will be like next week. I checked it today and it looked all good. I drove it today and it felt the best I have ever have.
