Thread: Question on intake and EGR
Results 1 to 5 of 5
  1. #1 Question on intake and EGR
    SE Level Member rodie1200's Avatar
    alabama
    A mechanic told me that my intake needs to be removed and cleaned on the inside along with the EGR valve.
    It seems to run ok until you start to climb a hill then it starts to misfire.
    Anyone else ever heard of this or have had this problem or is the mechanic blowing smoke?
    1996 GP SE 161,000 miles on it
  2. #2 Re: Question on intake and EGR
    TDCRacing
    Guest
    Is it just when you climb a hill or is it at a certain RPM? If it's a a certain mid point RPM it sounds like your coil packs.
    The EGR has nothing to do with the car misfiring. But tell him to go ahead and do that for you but be sure to tell him if it does not fix the problem that your not going to pay him for the work performed. I'd also get that in writing.
  3. #3 Re: Question on intake and EGR
    alabama
    It seems to misfire when climbing a hill. You can give it some gas and it seens to clear up and go on. At a stady speed I can't detect any misfire, only when it gets under a load going up hill.
    The check engine light is on and it shows a multiple cylinder misfire.
  4. #4 Re: Question on intake and EGR
    vicksburg ms
    sounds like coils to me too. my camaro did that once and i replaced coils and cheked the computer codes.
  5. #5 Re: Question on intake and EGR
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    hmm weird, maybe by some g force the spark plug wires in the rear are grounding out on sumthing????
  1. quick intake question
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:12 PM
  2. K&N Intake Question
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2009, 06:22 PM
  3. 2004 GP GTP intake question
    By deputy518 in forum General Tech Discussion
    Last Post: 12-17-2008, 10:19 PM
  4. question about my k&n intake
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:48 PM
  5. question about noise with my intake?
    Last Post: 08-18-2008, 08:37 AM
