Thread: Low side service port
Results 1 to 6 of 6
  1. #1 Low side service port
    CA
    I need to locate the low side service port on my 2001 3.1 in order to recharge the AC but im having trouble finding it. Ive narrowed it down to 2 ports that could be it but im not sure. The hose kind of fits on connector 1 however it blows out air when connected. It will not fit on connector 2 so i was wondering if i need some kind of adapter. Any ideas which one is the low side port? Thanks.
  2. #2 Re: Low side service port
    Pa
    Have you found the answer to your question? I have the same issue.
  3. #3 Re: Low side service port
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Low-side is #1 in that picture.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: Low side service port
    CA
    Thanks for the reply. Before I recharge it, my only concern is that when I connect the hose, it blows air out of the port instead of sucking it in, even with the engine on and AC on max. Is this normal? Just dont want the can to explode.
  5. #5 Re: Low side service port
    Feb 2008
    Yes, this is normal. Your low side is still pressurized. It should read anywhere from 35-55 PSI when charged. The hotter it is outside, the higher the pressure should read for a full charge.
    Whatever you do, DO NOT turn the car or AC off with the can/hose still attached. I've seen too many people do this out in our parking lot. Once the system starts to equalize, it can build up pressures in excess of 150 PSI and blow the bottom of the can out quite violently.
    BTW, from what I've been told R-134a cans are charged to around 100 psi. There is a relief "valve" made into the bottom of the can that is designed to blow if the pressure exceeds that by too much, so don't leave your cans sitting out in the sun very long, either.
  6. #6 Re: Low side service port
    CA
    Thanks for the heads up. Ill give it a try.
  1. Port on top of trans...
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2013, 11:07 PM
  2. Best way to do a home port job on a s/c and LIM
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 12:28 AM
  3. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  4. Port and polish
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2008, 02:57 AM
  5. Port my LIM???
    Last Post: 09-16-2008, 09:50 PM
