Thread: Throttle Body swap
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Throttle Body swap
    GT Level Member bkaab's Avatar
    Adrian MI
    You can do a direct swap from a 3400 which is a 56mm compared to the 3100's 52mm
    '01 GP GT Topswap GT
    '95 GP GTP 3.4DOHC V6
    '95 GP SE Gone but not forgotten.
  2. #22 Re: Throttle Body swap
    SE Level Member Berger's Avatar
    Feb 2008
    New Philadelphia, Ohio
    Being so close in size do you think the pcm would react to the switch ok?
  3. #23 Re: Throttle Body swap
    Adrian MI
    Quote Originally Posted by Berger View Post
    Milzy Motorsports - American Muscle, Reborn they have mods for the 3100
    They say-This 56mm 3400 throttle body will replace your 3100's 52mm unit. Installation is pretty straight forward, but may require transfer of parts from your current throttle body depending on the year and model of your vehicle.
    It don't say anything about the PCM having problems so it seems to me that it would work fine to me. Its only 4mm's but it should increase air flow by about 17 percent.
  4. #24 Re: Throttle Body swap
    Feb 2008
    so one from an 02 impala should work then right?
  5. #25 Re: Throttle Body swap
    Adrian MI
    what kind of car is this for?
  6. #26 Re: Throttle Body swap
    Feb 2008
    Its for an 03 3.1 GP SE. I found a stock tb for an 02 impala (which has a 3.4 motor) for cheap
  7. #27 Re: Throttle Body swap
    Adrian MI
    how much?
  8. #28 Re: Throttle Body swap
    Feb 2008
    found one for $20
  9. #29 Re: Throttle Body swap
    Adrian MI
    Wow good deal. I am not sure about that one. I know that the 3.4 TB off the GP, Carlo, Lummina, Baretta, Regal, Cutlass. Does it like simmular to the 3.1 TB? I have never seen the TB of of that car. Ill find some pics of it and get back with ya.
  10. #30 Re: Throttle Body swap
    Banned
    New Port Richey Florida
    The 3.4 vin x tb is made into the intake
  11. #31 Re: Throttle Body swap
    Feb 2008
    I looked at it and it looks exactly the same but with a slightly larger opening of course
  12. #32 Re: Throttle Body swap
    Adrian MI
    Go for it then. Thats one great price. Should increase air flow by about 17 percent
  13. #33 Re: Throttle Body swap
    Feb 2008
    thanks for all the help
  14. #34 Re: Throttle Body swap
    Adrian MI
    Tell me how it works I would like to do it to my car in the summer
  15. #35 Re: Throttle Body swap
    Feb 2008
    Ok but it will probably be mid next weak
  16. #36 Re: Throttle Body swap
    Adrian MI
    cool
  17. #37 Re: Throttle Body swap
    Feb 2008
    Installed the new tb, went from a 52mm to a 56mm and yes there is a difference in acceleration but not very much at all. It was worth the $20 I spent on it but I think I am going to find out how much it would cost to get it ported to 60mm. If its more than I would spend at MMS I will buy one from them. I do have a 2003 3.1 motor that has the larger intake manifolds so now my top end is the same as the 3.4 motor. Also I do have a 3" FWI and I noticed at wot it wasnt as throaty but I could hear that it was pulling more air.
  1. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  2. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
  3. throttle problem?
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-17-2008, 07:58 AM
  4. Ported and Painted Throttle Body
    By GTP SE in forum Visual/Body Modifications
    Last Post: 01-04-2008, 01:38 PM
