dies when i put it in drive....neutral safety switch??......zef said disconnect the batt. did and nothing happened. HHHEEELLLPPP!!!!!!!!!!!!
well i did but im in a hurry and no one responded...sorry!
oh and yep i unplugged the maf
well i would but i cant cause as soon as i hit the gas in gear it dies automatically
yea i tried to drive it both ways. ya sometimes it idles in gear but if it does as soon as i try to move it shuts off
no i tried listening to it but the pcv is so damn loud. but i dont think so
If the only thing you did was change the IAC, and now it doesn't run right...with the symptoms you described, I am thinking vacuum leak. Try taking the IAC out, making sure the o-ring is still on it, making sure the IAC hole is clean, lubing up the o-ring with some light grease or Vasoline, and reinstalling it.
no no no it was doing this before when it was idleing high. the iac fixed the idle problem just this now. do you know where i could find a vac line diagram?
yes that is exactly correct, but its fine in reverse. only messes up in drive gears
yes the car is warm. no even if i rev it it will just die, no matter what. it seems that it wants to die more when i hit the gas
That sounds like a fueling issue. Check the fuel filter to see if its clogged. Is there any ses lights? When you start the car let it run untill it heats up to operating temp and see if that happens. Keep us posted
you can get a vacuum diagram from a haynes manual for the car. were you able to drive the car at all before these things happened?
yes it was running perfect before this. i talked to a master mechanic and he said its probably in the tranny. ??????
