Thread: 1999 SE 3100 Replaced engine, Surging at idle
Results 1 to 2 of 2
  1. #1 1999 SE 3100 Replaced engine, Surging at idle
    Cathedral City
    I just replaced my engine with a used motor, also replaced fuel pump with a new Delphi. Engine seems to run good while it is cold, when it heats up to full operating temp my engine surges at idle from 300 - 1200 rpm and then dies. I am getting codes po131, po230, po452, and po463. Any advice on how to approach this issue.
    I would appreciate any help, the engine swap was easy enough but I'm not knowledgable enough to sort out the codes. Thank you for any help offered.
  2. #2 Re: 1999 SE 3100 Replaced engine, Surging at idle
    Cathedral City
    replacing the fuel regulator sensor fixed the problem...
  1. Check Engine Light on - Codes included
    By jcapone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 02:04 AM
  2. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
  3. Rear Bumper Removal and Fog Light replaced
    By cboth686 in forum General Tech Discussion
    Last Post: 12-27-2008, 07:09 PM
  4. Replaced engine. Now cricket appears. gotta kill it
    By FlatlinerD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 10:42 AM
  5. replaced new blower resistor and still no heat
    By nemesis in forum General Tech Discussion
    Last Post: 11-02-2008, 12:29 AM
