Thread: Starter Grinding
Results 1 to 5 of 5
  1. #1 Starter Grinding
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    I have noticed the starter grinding for a split second after I start the car. It's not bad once the engine has warmed up, but those first starts in the cold mornings are terrible. I'm hesitant to let it roll for fear of having to replace the flexplate. What do you all recommend? Has anyone else had this issue before?
    01 GP SE 3.1
  2. #2 Re: Starter Grinding
    take the starter out and inspect the gear on it for lots of wear.
  3. #3 Re: Starter Grinding
    Dec 2016
    IL
    Alright cool. Hopefully the flexplate isn't screwed. You think it's just the starter gear hanging up? Is this common for these vehicles? If the starter looks fine, should I try greasing it or should I just F it and replace the starter?
    It is unmistakably the starter. It makes the same sound it makes when the key is turned with the engine running. The starter itself looks like an easier job than what I have done before on cars so I should be able to tackle it.
    01 GP SE 3.1
  4. #4 Re: Starter Grinding
    Dec 2016
    IL
    Ended up replacing the starter and all is good. The flywheel didn't have an abnormal damage, just expected wear for it's age and a few "false starts". The starter that came off looked fine, but I think it was hanging up on retract.
    Thanks for the help!
    01 GP SE 3.1
  5. #5 Re: Starter Grinding
    back in the day you could buy just the starter solenoid, and replace it. thats the part where the wires go, thats the part that moves the gear out to the fly wheel. dont see em sold to often no more.
  1. grinding down the H bar in s/c????
    By Macksauce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2015, 01:26 PM
  2. Keep stock starter set up and add 4 gauge hot wire to starter
    By Jason97GrandprixGT in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2015, 08:21 AM
  3. Grinding Help
    By Jakescoots in forum General Tech Discussion
    Last Post: 04-14-2014, 06:05 AM
  4. weird grinding?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 12:19 PM
  5. cam grinding
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:37 PM
