Thread: throttle problem?
Results 1 to 4 of 4
  1. #1 throttle problem?
    hello i have a 96 grand prix (3100 as you all should know) but anyway uh today the throttle started stick (or something) on my old lady. i went out and checked it myself....drove it around for a half hour. then i stopped in the road and moved my other car then when i went to pull it in the driveway i slightly hit the gas and it seemed to want to hold that position. Although the pedal comes all the way back to the starting position (idle). would this be the tps? maybe something in the throttle body? maybe the throttle cable??
  2. #2 Re: throttle problem?
    Outer Space
    Open the hood and check the cable routing and springs... move it with you finger to see if there is any resistance.
    Do that and let us know what you find.
    I had a car that would do that and the spring on the TB was broke.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: throttle problem?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    The TB shaft could be sticking in the bore too.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  4. #4 Re: throttle problem?
    PA
    Best way to tell where the throttle is sticking is to disconnect the throttle cable from the throttle body. Then move the throttle body with your hand (car shut off) and see if you can feel anywhere that it might be sticking. Anywhere that feels a little tight or rough. You could just have buildup in your TB that needs cleaned out. Also, move the throttle cable by hand and see if that feels tight or sticky anywhere. You may need to lube this (if possible) or get another one.
    But it wasn't clear when I read your first post, but if the throttle is coming all the way back up, and the engine is still sitting there with a high rev, maybe try looking into your IAC. My wife's 3100 had an idle issue that the car was slow to return to idle, and sometimes it would drop down almost like it is going to stall. A used IAC from Ed (GTPED@msn.com) and all is well.
    2001 GSE
  1. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  2. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
  3. Ported and Painted Throttle Body
    By GTP SE in forum Visual/Body Modifications
    Last Post: 01-04-2008, 01:38 PM
  4. i didnt see where i could put this problem?
    By NME in forum Off Topic Discussion
    Last Post: 12-29-2007, 02:10 AM
