Thread: Needle in a haystack baffling overheat
Results 1 to 9 of 9
  1. #1 Needle in a haystack baffling overheat
    SE Level Member snaggs5899's Avatar
    Feb 2016
    Have a 03 gp se, of course the 3100 motor.
    Does NOT HAVE a blown head gasket, brand new thermostat, new water pump.
    Motor hits 250+ in a matter of a few min on first start of the day ( ie sitting 24 hours) and then a matter of second if it's shut off for 5 min.
    I'm at a loss, auto shop is at a loss aparently they have no clue. I asked for a flush on it Mayne it is that, but they don't have a flush machine aparently.
    Any other ideas on this?
    Sent from my SM-N910V using Tapatalk
  2. #2 Re: Needle in a haystack baffling overheat
    Did they even hook up a scanner to see what the sensor on the computer side is saying for coolant temp and not trusting the dash gauge.
    Temp sensors do go bad.
    And a stone cold motor won't overheat in a matter of a minute or two, that's never enough time for the coolant to get past 250ยบ.
  3. #3 Re: Needle in a haystack baffling overheat
    Buffalo
    In my 3100 I had a temp sensor for the ecu and a temp sensor for the gauge itself.
    Not sure if they changed it for the Grand Prix.
  4. #4 Re: Needle in a haystack baffling overheat
    Feb 2016
    It had a new sender on it when I got it, I don't believe they did, they called me and said when they pressurized the system coolant was gushing out of the water pump, 350 hucks later it's still over heating
  5. #5 Re: Needle in a haystack baffling overheat
    Buffalo
    Just curious , How's the LIM gasket ?
  6. #6 Re: Needle in a haystack baffling overheat
    Feb 2016
    That I don't know. But this shop charges to much, I'll have to take it apart myself. They charge 65an hour just to diagnose plus repair charges
  7. #7 Re: Needle in a haystack baffling overheat
    That's cheap LOL.
    We charged 105 an hour, same with every other shop in my town and the Chevy dealership. If it takes .5 hours it's 50-60 bucks but if we took the full hour it's 105.
  8. #8 Re: Needle in a haystack baffling overheat
    Feb 2016
    I got the car out of town. My shop of choice in town diagnose for free them it's 65 per hour but they don't charge book Raye if book says 2 hours but they do it in an hour no get charged 1 hour not 2
  9. #9 Re: Needle in a haystack baffling overheat
    Mar 2016
    Moberly,mo
    I know u said it does not have a blown headgasket but how do u know this if u do not know what condition the LIM is my brothers car was doing same thing over heading extremely fast I tore it down completely new head gaskets new lim new uim the whole nine years also changed waterpump gasket out and timing cover gasket due to it has coolant run threw it and now his car will start and run just fine no issues but this dang evap purge can blockage
    Sent from my SM-G928T using Tapatalk
  1. GM 3400 overheat
    By wa9zug in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-16-2014, 03:41 PM
  2. Overheat, Low boost
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 11:29 PM
  3. start; stall. replaced everything. it's baffling.
    By jessinator in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 04:52 PM
  4. 3.1 overheat
    By basmatic in forum General Tech Discussion
    Last Post: 03-08-2010, 05:07 PM
  5. Needle In Haystack?!?!
    By Toasty in forum General Tech Discussion
    Last Post: 02-26-2008, 02:17 AM
