Thread: po302 misfire after bad overheat...
Results 1 to 3 of 3
  1. #1 po302 misfire after bad overheat...
    Apr 2015
    las vegas
    Hello all I'm back again with a new/old problem. I have a 2003 3.1l with 173,000 miles.The other day my water pump went out on me on the freeway and the car shut off. I limped it home. Drove it to the auto store the next day, it was overheating, andback home. Replaced the water pump,and a couple hours later went to fill it with water. At this point I accidentally sprayed the coils and top of the engine pretty good with the hose.
    After filling and bleeding the system I noticed a check engine light came on and began blinking. I pulled the code and it was a po302.
    I checked for spark at the coil pack which it had and then I pulled the plug. The plug was fouled up pretty thickly and it had wet fuel on it that soon evaporated. I replaced the plug with a new one and the car ran good for about a block, no misfire at all according to my creader crp123 but then started flashing the service engine light, and registering misfires on 2 again.
    Any clues aside from you shouldn't run water in the cooling system? Oh and I've bypassed the heater core and removed the thermostat btw.
    Thanks!
  2. #2 Re: po302 misfire after bad overheat...
    Try some electrical grease on the coil packs and plug.
    Maybe even mist the wires late at night with water and watch for a spark jump, that will a show a misfire related to a faulty coil or wire arching.
    Or you overheated it so bad that it blew the head gasket and now has low compression in that cylinder.
  3. #3 Re: po302 misfire after bad overheat...
    Apr 2015
    las vegas
    Nope I blew a head gasket. I was blowing white smoke. 30 minutes with blue devil stopped the smoke. 50 minutes and the misfire disappeared. I've gone about 377 miles since I posted/ poured the blue devil and neither smoke nor misfire has apppeared
  1. 03 3.1l po302 cylinder number 2 misfire
    By basimpo in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-14-2015, 06:37 PM
  2. GM 3400 overheat
    By wa9zug in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-16-2014, 03:41 PM
  3. Overheat, Low boost
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 11:29 PM
  4. Overheat & Stall, What is next?
    By mojonba in forum Engine
    Last Post: 01-30-2011, 10:00 PM
  5. 3.1 overheat
    By basmatic in forum General Tech Discussion
    Last Post: 03-08-2010, 05:07 PM
