Thread: 2001 grand prix SE stalling and not starting!
Results 1 to 2 of 2
  1. #1 2001 grand prix SE stalling and not starting!
    Sep 2015
    Arizona
    I own a 2001 Pontiac Grand Prix and about two weeks ago I started to get a small issue with my car stalling when i would come to a stop at a red light and i would take my foot off the gas. It would only happen occasionally. I looked it up and there were people that said it was the idle air control valve so I replaced that and it was fine for a few days then it happened again so I talked to a guy at auto zone and he told me to replace the fuel filter and I did and again, it was fine for a few days. About two days ago it got even worse and stalled on my as i was driving and wouldst come back on. When I try to start it, it would get up to about 1000 RPM's and then stumble and die. If I give it gas when it starts, that is the only way it will continue to run. I have replaced the pcv valve, the line that runs from the pcv valve, cleaned the throttle body, and cleaned the mass air flow sensor, using both of the correct cleaners to do so. I have been told it might be a vacuum leak but i dont know where the vacuum leak could be. I have checked everywhere. What could possible be my problem?
  2. #2 Re: 2001 grand prix SE stalling and not starting!
    Kinda sounds crank sensor related if a 3800 motor in that SE of yours but at the same time it doesnt just because it's when you come to a stop. Most crank sensor failures come at anytime at random.
    And check engine lights or vacuum leaks?
  1. 2004 gtp starting and stalling
    By 00gtp04comp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2015, 10:45 AM
  2. Please help, 2000 Grand Prix starting/stalling problems
    By mjs173 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:22 AM
  3. Car stalling right after starting
    By sillypants03 in forum General Grand Prix Discussion
    Last Post: 03-01-2013, 03:46 PM
  4. 2001 Grand Prix Starting Issue
    By Badley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 10:12 PM
  5. stalling after starting
    By cruse in forum General Tech Discussion
    Last Post: 02-24-2010, 10:25 AM
