Thread: Shifting Issues
Results 1 to 10 of 10
  1. #1 Shifting Issues
    SE Level Member philly387's Avatar
    May 2015
    Michigan
    I have a 1998 Pontiac Grand Prix GTP Supercharged. The problem I'm having is when I get to 35-45 MPH the RPMs will decrease but the car still speeds up and doesn't seem like it is shifting, then it will shift shortly after that. So I'm thinking its when it goes into 4th gear. Is there a selenoid that could be bad? Any help would be appreciated. Thanks!
    Edit: maybe torque converter problem?
  2. #2 Re: Shifting Issues
    Pretty sure thats the tcc working properly
  3. #3 Re: Shifting Issues
    May 2015
    Michigan
    OK if it's working properly any other ideas?
  4. #4 Re: Shifting Issues
    your feeling the torque converter locking up. od dont kick in till 43 mph. and od dont really work till the trans is up to temp, or warmed up some at least.
    id say its fine.
  5. #5 Re: Shifting Issues
    Buffalo
    You can gently touch the brake without lifting off the gas and the tcc will release That way you know it was engaged in the first place.
  6. #6 Re: Shifting Issues
    May 2015
    Michigan
    Thanks for the help. Just sucks not having all that power when I want to get on it. It hesitates to get going fast again.
  7. #7 Re: Shifting Issues
    Apr 2015
    Columbus, OH
    Shift into 3rd first. Or use more foot on the pedal.
    Top Swapped 01 Imp
  8. #8 Re: Shifting Issues
    high way speed in what you think is od. keep the gas going with your other foot just tap the brake pedal, enough to make the brake lights come on. when you tap the brakes the tack should go up 2 to 400 rpm then drop back lower where they were. thats the tc unlocking, then locking back up.
  9. #9 Re: Shifting Issues
    May 2015
    Michigan
    I did that and it did seem to jump up in RPMs quickly after touching the break pedal
  10. #10 Re: Shifting Issues
    your fine then carry on.
  1. Still having shifting issues, really need help.
    By scheuvront1993 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2015, 06:26 PM
  2. Shifting issues...
    By mick777wauchope in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2012, 10:19 PM
  3. Issues shifting into 3rd/4th
    By Powertrike in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 12:32 AM
  4. shifting issues '97 GT
    By m1sterb0b in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2010, 04:12 PM
  5. Shifting issues in 96 GP with 3.1
    By girthman49 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-02-2009, 10:41 AM
