Thread: possible transmission problems???
Results 1 to 9 of 9
  1. #1 possible transmission problems???
    Mar 2015
    Stockton
    I recently purchased an 06 Grand Prix GXP. It has 4T65E high performance street/strip rebuild with reman torque converter and 3.29 gears. It also as a Tru Cool 4711 Cooler. The transmission was installed by Triple Edge Performance in Indiana. The previous owner had another company do the TCM reprogramming though. I drove the car home from her house, 137 miles. When I was almost home it sorta jumped gears. Did it for a second so didn't put much thought into it, thought it was just me making things up because it had been a long day and was late at night and I was tried by this point in time. Anyways, the next day comes and it drove great all day. Monday rolls around im drivinf around all day, then it starts this strange bucking almost like thing. Cruising through town at 30 mpg it wanted to shift to 4th but then kept jumping back and forth between 3rd & 4th gear. I got off the throttle and then back on it and it stayed in 4th. I keep an eye on the transmission temp and as soon as the temp gets above 180 this strange bucking starts. Not all the time, and only while cruising down the road. Whether its at 30 mpg or 75 mpg. It never does it while coming off of a stop. And it doesnt do it at all if the transmission temp stays below 180. Once the transmission temp reaches 180 it does this bucking thing, even if the temp comes back down to the 160 range it will still buck until the transmission has completely cooled down. Ive even put the car into manuel mode and made it shift to 4th and the car will still buck itself in & out of 3rd & 4th. Here it is 3 days later and it is still doing this bucking thing from time to time after the temp going above 180. I am currently talking with triple edge performance to see what I should do, but what else should I be looking at? Ive never experienced this in any grand prix ive ever owned.
  2. #2 Re: possible transmission problems???
    GTP Level Member buickman104's Avatar
    NYC
    Sounds like your Torque converter is locking at random.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: possible transmission problems???
    I would start off with a throttle body/maf cleaning. Odd readings can do strange stuff like that. Once those are confirmed then I'd start leaning toward something else. Toss up some pics and or if you know that the owner may have been a member. It's not the average person that has a TEP trans installed.
  4. #4 Re: possible transmission problems???
    Mar 2015
    Stockton
    I can not figure out how to post pictures. I dont know if the old owner is a member or not.
  5. #5 Re: possible transmission problems???
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Instructions are in a sticky in the introduction section. Basically get a photo bucket account, upload your pics there, then paste the img link here
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  6. #6 Re: possible transmission problems???
    Bastard Reptile's Avatar
    Kansas City, MO
    Have you contacted Dave directly?
    When you change gears in these thing the TCM needs to be programmed....I know that you've said it was done before, however, it's the typical way those cars act when something isn't right in the programming.
  7. #7 Re: possible transmission problems???
    Mar 2015
    Stockton
    http://s304.photobucket.com/user/Ash...?sort=3&page=1
    There's some pictures of the car.
  8. #8 Re: possible transmission problems???
    Kansas City, MO
    The invoice is for a stock reman converter, not a high performance one.
  9. #9 Re: possible transmission problems???
    Mar 2015
    Stockton
    Yea I've contacted Dave directly. Im first going to replace the pressure control solenoid. If that doesn't fix the problem Dave said it was probably never reprogrammed properly. Since thier shop didn't do the reprogramming. The previous owner had a different shop do the reprogramming.
  1. Transmission problems
    By Mattyg717 in forum Introductions/Noob Questions
    Last Post: 03-18-2015, 10:52 PM
  2. Transmission problems again on my '05 GP
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 06-13-2013, 02:32 PM
  3. 01 gtp transmission problems
    By built01gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2013, 11:34 PM
  4. Transmission problems!!!!!
    By tonio301 in forum Forum Bugs/Suggestions
    Last Post: 10-11-2012, 10:04 AM
