Thread: Need answer ASAP quick question on 04+ trans compatibility
Results 1 to 11 of 11
  1. #1 Need answer ASAP quick question on 04+ trans compatibility
    a buddy has an 04 base GT L26 and his trans is on its last leg. it wouldnt shift into 2nd gear until 110+ degree and the fluid color's burnt. he found a 04 trans from the JY but is from the L32. can he swap it directly w/o pcm tuning or is the gear ratios and/or cooler lines different? appreciate your help!
  2. #2 Re: Need answer ASAP quick question on 04+ trans compatibility
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Gear ratios ARE different.
    Trans lines MAY be different
    Valve body MAY be different if it came from a Comp G car
    Torque Converter I believe is different
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  3. #3 Re: Need answer ASAP quick question on 04+ trans compatibility
    If the tc is different then i imagine so is the flex plate
  4. #4 Re: Need answer ASAP quick question on 04+ trans compatibility
    Flex on most 04's are dual drilled, so no worries.
  5. #5 Re: Need answer ASAP quick question on 04+ trans compatibility
    Aug 2011
    'Merica
    Here is my flex on stock 05 gt n/a
  6. #6 Re: Need answer ASAP quick question on 04+ trans compatibility
    so it looks like just gear ratio is the only issue correct? if so, can the powertuner tune 04 to adjust the gear ratio? and if so then it's doable? assuming the cooler lines are also the same.
  7. #7 Re: Need answer ASAP quick question on 04+ trans compatibility
    Arizona
    04 and up should all be the same With no check valves in the fittings
  8. #8 Re: Need answer ASAP quick question on 04+ trans compatibility
    Oct 2012
    Pinckney, MI
    Yes, you should be able to correct the PCM with a DHP Powertuner. (That's what I used on mine)
    Not all 04+ cars had the same checkball setup. My 04 GT (Original Trans) had a trans with the checkball in the valve body, but my donor car (04 CompG with a SeRTA Trans) had the check ball in the fitting.
    Make sure the trans he's getting isn't out of a CompG car (Tap Shift Transmission) as the valve body and channel plates are different and incompatible.
    -Rob
  9. #9 Re: Need answer ASAP quick question on 04+ trans compatibility
    coolbeans, appreciate all of your help guys. worse case is he buys the entire motor, trans, pcm, and wiring harness.
  10. #10 Re: Need answer ASAP quick question on 04+ trans compatibility
    Oct 2012
    Pinckney, MI
    If he's going that route, grab the fuse box and ABS module as well. They are different between the 04 GT, 04 GTP, and 04 CompG.
    I would only recommend it if the car is a Non-CompG though, there are more changes required if you want to swap over to a CompG drivetrain.
    I did basically the same thing in my car.
    -Rob
  11. #11 Re: Need answer ASAP quick question on 04+ trans compatibility
    He'll know once he goes to check it out more thorough.
  1. Need Keys Programmed (need a answer ASAP)
    By sLpGPGT in forum General Tech Discussion
    Last Post: 03-08-2014, 04:03 PM
  2. quick question ( starter) need asap!
    By titanfan12 in forum General Grand Prix Discussion
    Last Post: 02-16-2014, 08:16 PM
  3. Offset question please answer asap
    By zerolimitsgt in forum Tires & Wheels
    Last Post: 04-03-2010, 06:35 PM
  4. need a quick answer will these fit??
    By tjsmithey in forum Tires & Wheels
    Last Post: 02-14-2010, 09:09 PM
  5. Quick Question, Easy Answer (bolt size)
    By alexsmith0913 in forum General Tech Discussion
    Last Post: 08-22-2009, 05:25 PM
