Thread: Help! Grand Prix will not shift into Park.
Results 1 to 16 of 16
  1. #1 Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    I hope I am posting this into the right place. I have a 1999 Grand Prix GT that has a random issue. I can drive it sometimes and no issue and others times it will not go into park. It goes into all other gears just fine. The first time this happened my son was driving and he cut the car off with the transmission in reverse and the key stuck in the ignition. I was able to use the release switch under the steering column to release the key and once I did that the car went into Park with out a problem.
    I don't think it is the transmission because I check the shift linkage cable and it moves freely plus I also removed the linkage cable and was able to shift the transmission.
    I have searched and read a few post with people having issues with wires going to the shifter so I removed the top off of the shifter console and did not notice anything out of place with any wires. I am sort of stuck on what to troubleshoot next.
    The last time it happened I was able to re press the brake and wiggle/force the shifter and it finally went into Park.
  2. #2 Re: Help! Grand Prix will not shift into Park.
    I have seen a few cars where the shifter itself gets worn and will bind or be difficult to move. Might be worth looking into.
  3. #3 Re: Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    Thanks Bill! I will look into that. Has anyone heard of the Shift Lock causing an Issue like this? When I google or search shift lock it mainly talks about people who are not able to shift out of Park.
  4. #4 Re: Help! Grand Prix will not shift into Park.
    I have not.
    Issues like this it typically is the shifter or the cable.
  5. #5 Re: Help! Grand Prix will not shift into Park.
    my shiftier needed to be lubed up. the button was hard to push to get it out of park. spray lube and it came back to life.
  6. #6 Re: Help! Grand Prix will not shift into Park.
    BS.. Scott used Dude Lube
  7. #7 Re: Help! Grand Prix will not shift into Park.
    nah, not this time. used white lithium. looks the same tho lol
  8. #8 Re: Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    Okay I just found this video from RareGMFan's post https://www.youtube.com/watch?v=6XBPL9v02WQ
    I will take a look at this this weekend. To see if my issue is related to this. Hopefully it is something simple like this. Gotta love GM things may break but sometimes they are easy to fix. I will report back what I find out later this week.
  9. #9 Re: Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    Dude lube on the shifter. My car would never be the same after that Lol.....
  10. #10 Re: Help! Grand Prix will not shift into Park.
    that vid is more if its stuck in park. not going back into park. its should just slide in like butter.
  11. #11 Re: Help! Grand Prix will not shift into Park.
    that vid is more if its stuck in park. not going back into park. its should just slide in like dude lube.
    There
  12. #12 Re: Help! Grand Prix will not shift into Park.
    lol nice re quote.
  13. #13 Re: Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    When it works it slides in like butter but when it doesn't it feels like is hitting something to prevent it from going forward. I have never tried this but I am assuming that a GP will not let you shift from drive to Reverse or Park unless your foot is on the break to prevent damage to the transmission. This is just me thinking out loud. I will have to play closer attention to the shifter button also to see if it can be pressed in when I am experiencing this problem. I can't remember if that was a problem or not.
  14. #14 Re: Help! Grand Prix will not shift into Park.
    i dont have to hit the brakes to get into reverse, just the button on the stick, good old reverse lock out.
  15. #15 Re: Help! Grand Prix will not shift into Park.
    Sep 2014
    United States
    Ok I think I figured out my issue. I noticed that if I wiggled the shifter from side to side and pressed it hard into gear it would go in Park and start working fine. After watching that video I noticed that the button on the gear shift has to push in a rod to release the shifter and allow it to move. I think my issue was the pin that holds the shifter knob with the button on it start to pull up and the button was not pressing in on the rod to allow the shifter to move.
    So I pushed the shifter knob all the way down on the shifter and made sure the pin that holds it in place was all the way in. I will keep an eye on this to see if my issue is completely resolved or not.
  16. #16 Re: Help! Grand Prix will not shift into Park.
    Yeah, that'll do it too
  1. Grand Prix won't shift out of park, and the key won't come out
    By dg8srt in forum General Grand Prix Discussion
    Last Post: 08-31-2014, 10:50 AM
  2. Car won't shift out of park.
    By gpbastard in forum General Tech Discussion
    Last Post: 03-24-2014, 01:21 PM
  3. Can't shift out of park
    By disallow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-08-2014, 03:30 PM
  4. cant shift out of park
    By gtpenthusiast in forum General Tech Discussion
    Last Post: 07-12-2013, 07:58 AM
  5. Grand Prix stuck in park
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 05-14-2013, 09:15 PM
