Thread: trans bolting up
Results 1 to 8 of 8
  1. #1 trans bolting up
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    would a transmission from a 3.8 na bolt up to the sc motor? aren't the internals just different?
  2. #2 Re: trans bolting up
    Yeah it'll bolt right up. Assuming you're asking about a 98-02 it'll be fine just have a different gear ratio.
  3. #3 Re: trans bolting up
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Converter is also different, you'll have to either use the hd converter with your L67, or swap an L36 flex plate onto it to use the non hd converter. The non hd one is lighter and stalls a bit higher, I'd use that one if you're not heavily modded.
  4. #4 Re: trans bolting up
    you would also need the pcm tuned for the gear change.
  5. #5 Re: trans bolting up
    Jul 2010
    Oh ok I was looking for my brother in laws dad,he has the impala ss either 04 or 05,he wouldn't be getting on it so I figured a non hd would do,what would it do if it wasn't tuned?
  6. #6 Re: trans bolting up
    some times they blow up. some sorta failure can be expected cause its not gonna shift right.
  7. #7 Re: trans bolting up
    Apr 2011
    Elk Rapids, Michigan
    NA transmissions use a longer axle on the passenger side because the differential is shorter. You'd need a trans out of a newer car as the connector has a different pin arrangement than the 98-02 cars. The 02 may be different. Final gear ratio on the NA is 3.29 versus 2.93 on the SC trans.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  8. #8 Re: trans bolting up
    Apr 2011
    Dave at Triple Edge Performance could probably help. He's a sponsor on this forum.
  1. non-super 3.8 trans vs. supercharged trans?? Any difference
    By chicagochuck in forum General Tech Discussion
    Last Post: 06-19-2014, 11:54 AM
  2. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  3. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
  4. Replies: 7
    Last Post: 01-26-2010, 10:07 AM
  5. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
