Thread: Trans rebuild
Results 1 to 13 of 13
  1. #1 Trans rebuild
    Feb 2010
    TN
    Ok torque converter not working properly, and it will not go into over drive. Local guy here who is known to be a good transmission guy says a complete rebuild of my trans will include all hard parts, replace only the bad solenoids, replace one solenoid with one that will increase the line pressure to 220 and install a Neil's shift kit. He says since my trans has 341,000 miles on it, he would rather do a rebuild rather than just change solenoids and add a shift kit. Just solenoids and kit $400-$500, the whole rebuild $1,200-$1,500 rebuild is one year unlimited mileage warranty, the other no warranty. I am leaning to the rebuild what do you think? and is the price good?
  2. #2 Re: Trans rebuild
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    what year is the car? that will give some insight
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  3. #3 Re: Trans rebuild
    Feb 2010
    TN
    1997 grand prix gt n\a
  4. #4 Re: Trans rebuild
    May 2008
    Schuyler, NE
    Yeah with those miles, I would do a full rebuild.
  5. #5 Re: Trans rebuild
    Mar 2012
    NC
    There is no solenoid that controls line pressure on a 97 3800 NA. That trans has a vacuum modulator that controls line pressure directly and if it goes bad it can cause lots of fun things to go wrong. 1-2 and 2-3 have solenoids...then there's the TCC solenoid and the TCC pulse width modulation solenoid.
  6. #6 Re: Trans rebuild
    A quick google search
    Here's info about 4T60's that Sonnax has listed for problems and what typically goes wrong. Third one caught my eye as it's talking about TC.
    http://www.sonnax.com/resources?utf8...lter#resources
    A fix kit they offer
    http://www.sonnax.com/parts/3033
    Tons of info on it.
    http://www.sonnax.com/units/264-4T60-E
    Transgo
    If we look at their shift kit jr, it includes valves for the valve body etc.
    http://www.transgo.com/products.php?...product_id=220
    In their product catalog it looks like they have the kit plus an accumulator kit
    http://www.transgo.com/products.php?...&parent_id=105
    Personally, I'd suggest reading up on all the info you can find for the trans (tons on Sonnax) and discuss those things with your builder. Make sure he goes right on through and does it all.
  7. #7 Re: Trans rebuild
    Feb 2010
    TN
    So am I to assume that when the builder told me 340,000 on that trans and just now showing a problem is unheard of he was right? LOL, he wanted to know how I managed that and I told him drive fast but sane and do a fluid flush and filter change every 100,000 miles for the first 200,000 miles then after that just a fluid and filter change every year and a half
  8. #8 Re: Trans rebuild
    I would also look into any upgrades that Sonnax/Transgo has available for your 4T60. In the 4T65 there are a lot of upgrades to the valves that require special tools to ream etc and they make a huge difference. By 150K most 4T65's are sloppy, the 4T60 valve body doesn't appear to be super different from a quick exterior view, but maybe it is.
  9. #9 Re: Trans rebuild
    Mar 2012
    NC
    Valve body upgrades are possible for the 4T60 just like the 4T65. The major difference between the two is actually more minute...it's the way MLP is directed through the valve body itself. All the bores can still be reamed...the valve body can be upgraded in basically the same fashion as the 4T65 as long as parts are available. You can even utilize some of the 4T65 parts if you know what you're doing.
  10. #10 Re: Trans rebuild
    Feb 2010
    TN
    there's the TCC solenoid and the TCC pulse width modulation solenoid. Thats what I was trying to think of he said these are bad
  11. #11 Re: Trans rebuild
    I've seen 4t65's at 300K ..
    It's uncommon but it happens
  12. #12 Re: Trans rebuild
    Mar 2012
    NC
    No...I've seen many 4T60's over 300k miles. I think it's more unheard of for a 4T65 to last that long.
  13. #13 Re: Trans rebuild
    Feb 2010
    TN
    I will research that Bill in the meantime is that a fair price and warranty guys?
  1. Trans rebuild kit for HD
    By camopaint0707 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-26-2013, 12:44 AM
  2. Rebuild fail or trans?
    By Overboost101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 12:17 PM
  3. Trans rebuild
    By Logan541 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 04:06 PM
  4. Can I rebuild my Trans????
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2010, 01:55 PM
  5. Engine and Trans rebuild??
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 03-08-2010, 11:35 PM
