Thread: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 97
  1. #41 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Arizona
    Quote Originally Posted by Turbocharged400sbc View Post
    id say that looks like a whole lotta "yer fawked"...i tore one apat for the trans case core (gotta be skillfull to remove starter and not snap the damn bell)
    there was like zero room, the engine to diff brace/bracket is like 1/2" wide and the 80e is at least two inches bigger OD at the diff surface.
    id bet it'd be possible, but it'd take modifying the case and block
    Yea...memories of me doing a trans swap on a caddy years back kind of flashed in my head. Figured as big as that ****er is there'd be no hope. Ah well life goes on
  2. #42 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Antioch, IL
    im with 98 **** the 65e and get going on 80e, let the 65e die
    2009 Challenger SRT8
    Expert at being gay.
  3. #43 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    yeah but without it being a bolt in kit most of ya are ****ed
    ~James~ Psychotic Gearhead
  4. #44 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    May 2012
    Where winter never ends
    Make a decent 80e kit!
    2000 Regal - Winter Beater
  5. #45 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    sure.
    buy a G/H/C/B body, swap in using all oem parts
    at this point there's far more untapped potential into a 3800/th400 swapped catera, which is nearly a midget GTO with far more ****yew potential. though ditch the frontend cladding for the opel ****...
    if i didnt have a POS 84 toyota wagon that looked a crapload like a mini GN/regal waGN, id be doing a catera.
    all the joys of a rwd 4th gen F body....without that ****ing cowl and high price tag
    saw an 01 with a blown motor (youll see that alot) for 1200$
    id paint the "ziggy" duck on the back flippin ya off...
  6. #46 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    cmon people when are people going to come to reality 6k is absurd for a bandaid 65e......
  7. #47 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    just remember, you can sleep in you car, you cant race a house.
  8. #48 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    i took a channel plate to the saw and ****ed **** up, now you guys can see the packaging constraints.
  9. #49 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    How much would guys spend on a 4T80E conversion.
    I have a good amount of runs on mine at high power level and high traction level.
    My motor mount setup have held up great.
    It would be an expensive conversion.
    We would have to build you guys a custom Cradle with mounts built into it. And then build custom mounts to bolt on to your 4t80e trans and a custom bracket for the block to the trans.
    And drill your flywheel to the 4t80e specs and have more spacers cut CNC to the exact specs to match the 4T80E torque converter bosses.
    I would be at least 2 grand upgrade + the trans and parts and I'd have to build like 10 for it to be worth it.
    I'm planning to do the front trans too on my twin engine so it's bulletproof.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  10. #50 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Id throw my wallet at someone to mock me up a cradle and a DIY kit for 2k..... Hell all I'd like is the damn mount placement and a weld *here* type template or something and id be happy, until I get to mock one up.
  11. #51 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Antioch, IL
    Quote Originally Posted by TwinV6GTP View Post
    2k upgrade.... turbo trans is $3600
  12. #52 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Quote Originally Posted by ITHURTZ View Post
    2k upgrade.... turbo trans is $6000
    Fixed for you...... and that's still a band aid
  13. #53 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    May 2013
    Gatineau
    The best way to do it is to test fit each set to be 100% sure. Its a tough sqeeze and the motor has to be moved forward. That trows off setups
  14. #54 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Antioch, IL
    Quote Originally Posted by 98ChainStretcher View Post
    well quoted 36.. wasnt a 500+whp build though.
  15. #55 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    May 2013
    Gatineau
    Final price with everything will be higher.
    But easy to find trans and axles.
    Only need a good lsd
  16. #56 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    Nov 2012
    Erlanger, KY
    Thanks.. but I already have one..
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  17. #57 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    and this is a large reason why we went to a clean slate and new chassis.
    i looked at modifying the g/h body for the W body...then i planned out a tubular subframe, then found i wanted to ditch the ****ty stock LCA's, ditch the oem subframe bushings....etc etc
    i had a hard time seeing someone want to spend that kind of coin when the G/H bodies are about the same weight and a better starting platform since the 80e bolts in
  18. #58 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    hangover park IL
    Quote Originally Posted by jdredd View Post
    rub it in... dick
  19. #59 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    gardner,mass
    Twin will be our savior
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  20. #60 Re: GI 2.93 1" gearsets, "Mr Norris' third fist" brace
    This 600 hp turbo 4t80 bonnie...... Someone please do it!
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  4. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
