Thread: Solenoid part numbers
Results 1 to 12 of 12
  1. #1 Solenoid part numbers
    Jun 2012
    Southern NJ
    I'm looking for A, B, PCS, and TCC. My trans has an intermittent issue where sometimes it doesn't like to go into 4th and after about a mile or so in 3rd, it'll finally go into 4th.
    The gears all feel fine, so I'm thinking it might be a solenoid issue despite no code.
    I'm gonna throw all of them at the trans and see what sticks. If it's still a no-go afterwards, it might be time to get a trans out of the pick n' pull.
  2. #2 Re: Solenoid part numbers
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    Most guys go here for one stop shopping....
    http://shop.tripleedgeperformance.co...itches_c24.htm
    I took a chance on my pressure switch manifold and got that from a company called Buffalo Engine Components. They have all the solenoids plus gaskets for cheap. I was just a little hesitant on some of the heavier solenoids to get them here when Triple Edge offers guarantee (with a diagnostic from a Trans shop).
    I would also recommend replacing the 4th gear while you are in there and a shift kit too. I just searched for the hardened 4th gear on ebay and do some research on the forum for the best shift kit for you. Hope this helps.
    Last edited by SilverBulletWI; 10-05-2014 at 05:52 AM. Reason: Don't want quote to appear
  3. #3 Re: Solenoid part numbers
    I'm also thinking the 4th clutch hub is a good thing to add while you are there.
  4. #4 Re: Solenoid part numbers
    Apr 2014
    Milwaukee, WI
    This is what I was referring to when I said 4th gear, I just used the wrong terminology. Sorry about that.
  5. #5 Re: Solenoid part numbers
    I was agreeing with ya.. meant "I would too"
  6. #6 Re: Solenoid part numbers
    Jun 2012
    Southern NJ
    Alright, hit me with some straight talk: can that be finagled while the trans is still in the car? I don't want to take it out, which is half the problem.
  7. #7 Re: Solenoid part numbers
    Apr 2014
    Milwaukee, WI
    This will explain it step by step. No problem helping you here but search the forum a little for this stuff too. There is a lot of help in the how to write ups section.
    http://www.grandprixforums.net/showthread.php?t=54448
    How to transmission 4th gear side cover access
  8. #8 Re: Solenoid part numbers
    Yeah.. follow the procedure Silver posted, it looks solid to me.
  9. #9 Re: Solenoid part numbers
    Apr 2014
    Milwaukee, WI
    Modesty at its best...lol.
  10. #10 Re: Solenoid part numbers
    It gets better.. apparently when I was doing all those write ups, I felt that things were super simple. Found it by mistake.. the word "ea sy" (without spaces) is in almost every write up..lol
  11. #11 Re: Solenoid part numbers
    Apr 2014
    Milwaukee, WI
    I've noticed you usually tell people to search for the repair topic plus "ea sy" I think it is in order to find your write ups..lol.
  12. #12 Re: Solenoid part numbers
    It is now.. I happened to search on it one day thinking I had just said it. Nearly all the how to's popped up. Hit me as funny, seems I find something in the how to's as ea sy.
  1. LIM/UIM part numbers
    By pwrhouss in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2014, 12:31 PM
  2. ROTOR part Numbers
    By TNTSS in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2013, 01:59 PM
  3. Part numbers
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 08-08-2013, 07:11 AM
  4. Brake Part Numbers
    By Suaveat69 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2010, 10:02 PM
  5. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
