Thread: Lost all shifts but tryna figure out what it could be
Results 1 to 20 of 23
  1. #1 Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Driving my car yesterday night i notice my car couldnt shift to the next gear so i baby it and out of nowhere she just started revving no shift just revving so i pulled over asap popped the hood to see what was the problem started the car again put it in drive the car was fine... then 10 secs later it did the same thing wtf? High revs with no shifting so i pulled over got the car towed to my house for further inspection my question is could it be my trans is kicked the bucket? Need a new flexplate? I'll visually inspect the car tomorrow i just want some of you guys opinions about it just happen out of no where thanks here is a vid of the noise
    Gtp Diagnosis: http://youtu.be/qa9idrm1Q_I
    Also like to note when i go to the bottom of the car you can hear more of the noise by trans, starter area thats why im thinking its the flexplate..
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: Lost all shifts but tryna figure out what it could be
    HUDSON
    I hear huge exhaust leaks. Also, to test the flexplate, remove plastic instpection cover and remover the bolts to the torque converter, and slide the converter away from the flexplate (should move about 1/4), tap the flexplate with a wrench, if it rings, it is good, if it has a dull thud sound when tapped it is broken.
  3. #3 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Exhaust is loud no mufflers smh lol that what you might notice.. i'll test it when i get hm.. if the flexplate is trash easy replacement
  4. #4 Re: Lost all shifts but tryna figure out what it could be
    Based on the symptoms, you have a ton of stuff in the pan. What happens when you turn it off is all the stuff falls back into the pan. When you start it and put it in gear it all gets picked up, works for a moment until the filter clogs then you loose pressure and w/o fluid you have no workie.
  5. #5 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Ahhhh gotcha simple fix then? Replace filter and drop the pan i'll check if it needs fluid if so i'll replace after i drop the pan and replace the gasket
  6. #6 Re: Lost all shifts but tryna figure out what it could be
    You bet. I found it to be a super easy fix. I dropped the pan and found this
    If you think that is fixed with just a pan drop...you are in for a large wake up call.
  7. #7 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Always looking for the simple fix.. lol who wouldnt? but yeah guess either rebuild or grab a new one
  8. #8 Re: Lost all shifts but tryna figure out what it could be
    Aug 2011
    'Merica
    If this one grenaded, then I'd purchase on from TEP. Or start buying GMR parts......
  9. #9 Re: Lost all shifts but tryna figure out what it could be
    You'll know more when you drop the pan.
  10. #10 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    I'll drop it tonight.. and see what can be done hopefully if nuked i'll grab a tep parts
  11. #11 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Update:
    Trans is toast 4th is right in the pan... new trans in by next week she lasted for 200k so i cant be mad its nuked it served its purpose
  12. #12 Re: Lost all shifts but tryna figure out what it could be
    Details on the built trans?
    04 Comp G.
  13. #13 Re: Lost all shifts but tryna figure out what it could be
    Thats the transmission that came in the red car? Didnt think that trans had many miles on it?
  14. #14 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    03 Hardened 4th Clutch Gear Shaft
    Sonnax Valve Body
    Shift kit
    Trans cooler (if it comes in the mail quick enough if not i'll install afterwards)
    Trans has 3k on it so it should be durable
    Quote Originally Posted by 98FordLovinVet View Post
    It did but it was rebuilt about 20k ago from the owner dont know how true but its nuked so f**k it
  15. #15 Re: Lost all shifts but tryna figure out what it could be
    Feb 2013
    Missouri
    Depending on how it was rebuilt, and what parts were used, I don't know if I'd consider that built. I don't know if it'll stand up to the 3.0\e85 setup...for long at least.
  16. #16 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Booba5185 View Post
    Youre right booba and honestly im not really gonna rag on this setup knowing the stress it will go through but for now this is my setup until im ready to do a full rebuild when my funds allow
  17. #17 Re: Lost all shifts but tryna figure out what it could be
    Feb 2013
    Missouri
    If has the hardened chains and you have a tune for higher pressure it'll help, but you're gonna want a 7\8 chain soon.
  18. #18 Re: Lost all shifts but tryna figure out what it could be
    Banned
    Jan 2013
    maryland
    Exactly what i was thinking im gonna need it soon but cash is tight and i need a trans.. i REALLY want a 1"Gmr chain but cash is tight for car mods.. but eventually ima scrap the money and grab one
  19. #19 Re: Lost all shifts but tryna figure out what it could be
    Did you get any closer pictures? You say 4th is in the pan, but I thought I saw a couple needle bearings. That would be a bad diff typically.
  20. #20 Re: Lost all shifts but tryna figure out what it could be
    Besides the needle bearings look at all the clutch material!! No way id attempt to save that trans.
  1. Tryna open my car hood and im locked out of my car
    By jayroca in forum General Tech Discussion
    Last Post: 06-22-2014, 09:49 AM
  2. cant figure it out
    By gwizz69 in forum General Tech Discussion
    Last Post: 10-19-2011, 05:43 AM
  3. 98 gtp, Lost 4th gear for a day, Shifts hard, Hesitates
    By shawnooohhh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2011, 01:32 PM
  4. dhp 6k shifts
    By blowfishRus6 in forum PCM Tuning
    Last Post: 10-11-2009, 11:16 AM
  5. car only shifts when it wants to??
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2009, 04:06 PM
