Thread: fluid options
Results 1 to 11 of 11
  1. #1 fluid options
    Sep 2013
    Massachusetts north shore
    I am doing a intense shift kit on my one year old low mile rebuilt transmissions that has less than 10k city miles and i am wondering whats your opinion on the best fluid i am trying to decide on walmart supertech dexron 6. GM approved or valvoline max life synthetic multi purpose atf that valvoline recommended for use in dexron 6
  2. #2 Re: fluid options
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Any dex 6 thats GM approved/licensed, I used valvoline brand dex 6 from napa but the Walmart super**** brand its fine if approved which I think it is.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: fluid options
    Sep 2013
    Does anybody have any specs for different transmission fluid
  4. #4 Re: fluid options
    Apr 2012
    Dayton, OH
    Specs as in?
    2012 F150 STX
  5. #5 Re: fluid options
    Sep 2013
    Viscosity hot cold ,pour point , from one brand to another
  6. #6 Re: fluid options
    Dec 2010
    DMV
    Don't have to get that detailed. It's just trans fluid. Anything that's approved by gm will work fine.
  7. #7 Re: fluid options
    Apr 2012
    Dayton, OH
    That im unsure of, you would have to look at the manufacturers website or contact them. I do know that the GM licensed fluids have to meet GM spec. Me personally wouldn't run the AT fluid that works in multiple applications that most brands have only because I'm anal like that even tho it could or does meet GM spec but its not approved.
    2012 F150 STX
  8. #8 Re: fluid options
    Dec 2012
    Where 4T65E's were born
    I'd suggest dexron 6 fluid only, assuming the rebuild included the seals and gaskets. It is a better fluid and that is a fact. I say if seals and gaskets because it has a higher flow rate as it's a semi synthetic fluid from gm. And higher flow rate means more leak down if seals are worn.
    Valvoline offers a full synthetic Dex 6 which is what I would use. Its a little pricey but is good stuff.
    Sold.
  9. #9 Re: fluid options
    Enfield, CT
    Valvoline Dex 6 is good but I went with ACDelco Dex 6 from the dealer cause I got a sweet deal
  10. #10 Re: fluid options
    Apr 2012
    Dayton, OH
    I used Valvoline Dex 6 in my moms LaCrosse, I think it was like 5.99 or 6.99 a quart at a local napa.
    2012 F150 STX
  11. #11 Re: fluid options
    Sep 2013
    I am going to return the. Maxlife for super tech. Dexron 6 i dont like the fact its multi vehicle formula And get some lube guard platinum thanks guys
  1. need options
    By redlinepontiac in forum Off Topic Discussion
    Last Post: 12-31-2011, 11:00 PM
  2. TB and MAF Options ?
    By Lawngoose in forum General Tech Discussion
    Last Post: 08-23-2010, 07:59 PM
  3. 2 options.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-27-2010, 12:27 AM
  4. TB options
    By 4drgt in forum 04+ Specifics
    Last Post: 09-12-2009, 03:14 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
