Re: PSA: Transmissions DO NOT run off magic smoke: Proof inside! (DIY Rebuild time gu
That was always my feeling. Plus..my garage was often clean enough that it wasn't an issue. Barefoot engine/trans swaps. I dare ya
Unless you wear steal toe boots, what more will shoes protect anyways if you drop something?
I did mine in flip flops, and it wasn't so bad, until you get transmission fluid on it. Then it gets slick and you damn near fall out of your own shoe, lol.
Booba5185
Been there too.. just like a wet concrete floor in flip flops.. man..that can be a serious windmill opportunity
Damn it, where were you with this idea over the last few days? That wouldn't been awesome.
I wear steel toe boots and jeans when I work on a car, no matter the temp out. I like my toes not cut or broken.
We like to live on the wild-side. Keeps our reflexes fast and helps our breaking dancing. Hey we could be wearing Crocs. It COULD be worse!
I look at it this way Joe. typically my feet aren't under the car when I am. Plus..if that 4x4 or chain let go...I'm crushed
True, but at least you will have nice feet......lol
Haha I have tennis shoes on today...only because I w
Am welding
Updated first post with more goodies! I know you would all prefer if I put them as the next post and what not but for future readers I want them to be able to just scroll the first posts and see it all instead of hunting and missing something. Sorry!!
Loading 80 bazillion pictures at once sure does almost freeze my computer.
lol sounds like a personal problem
Loaded fine on my computer.
And nice Crownline :cool: don't see too many yellow ones.
Nice job on the bracket.. Although you might want to cut down the piece that sticks toward the side cover side. That'll get in the way.
Lmao... I know it doesn't matter, to each his own. Certainly not worried about dropping an engine or anything crazy on my toes with flip flops, but a wrench dropped always seems to find the most painful spot to hit on it's way down!
And now you know if you do happen to drop something on your freakin foot while working in flip flops, the first thought in your head will be to say @#&%@ you Coolone! Hahaha
Lol'd - tranny fluid windmill
I was flipflop or barefoot when the handle slid off the metal rod you use to turn the engine hoist. Right on the big toe nail.
Alright guys Update time!
Build went well, Have to install the Valve body/channel plate combo from Dave then seal everything up. I found a local trans shop that has a trans dyno, I am going to call and see if I can borrow it to test it out and not waste time putting it in if its DOA.
Chain and IS are all installed. Tight fit and a pain in the ass but it went in.
3000 stall converter showed up and is ready to go in.
http://i.imgur.com/OSNdqpw.jpg
Christmas break is when the thing will be installed provided it works.
