I wanna get mine fixed right
Less then 180
Between 180 - 190
Between 190 - 200
More then 200
I wanna see the difference between stand alone and in series to see if its enough to switch them. Well ace is gonna have everything all hacked up, he should be the guinea pig.
Mine's mainly 167*. I **** you not but I also have an overkill tune. With my stock pcm i was seeing 190's. It's only hit 174* once in a traffic jam. other thing I should mention is how i love it when I shut the car off, my fans turn on right away regardless of temp due to the overkill tune.
does anyone here live in Michigan or Canada that uses the stand alone in there car and drive it during the winter?
I plan to convert mine to Stand Alone, since my stock lines are leaking badly. I plan to have TEP build me this kit:
http://www.grandprixforums.net/threa...Grand-Prix-GXP
Should work great, I'm not concerned with it running too cold in the winter.
-Rob
You can easily build your own tep kit for cheaper. And remember even stainless braided lines leak too..
