View Poll Results: What is your normal trans temp daily driving?
Voters
14. You may not vote on this poll
  • Less then 180
    3 21.43%
  • Between 180 - 190
    3 21.43%
  • Between 190 - 200
    5 35.71%
  • More then 200
    3 21.43%
Thread: 04+ Trans Temp (Daily Driving)
Results 41 to 60 of 70
  1. #41 Re: 04+ Trans Temp (Daily Driving)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Return line is the top one on the rad if you need to know.
    2012 F150 STX
    - Gonna be a race truck
  2. #42 Re: 04+ Trans Temp (Daily Driving)
    GTP Level Member
    Aug 2012
    st louis park, MN
    Just to clarify how this is supposed to work:
    A stock system send the transmission fluid through the radiator to cool. The problem with this is that the transmission fluid temp will "follow" your car's coolant temp.
    An "in-series" system places a mini radiator AFTER the radiator to provide additional cooling of the transmission fluid after it has already been cooled by the engine radiator. This provides a mild improvement and a good option for most of us. Also, for those of us in cold climates, the warmth of the engine coolant will help warm the transmission fluid in the winter - a good thing.
    A "standalone" removes the stock radiator from the system and the transmission cooling depends solely on an additional, appropriately sized, radiator for the transmission only. This provides the most efficient cooling but I'm not familiar with how to size correctly.
    If you placed your transmission cooler before your engine radiator the transmission fluid will be cooled before the engine radiator and then warmed up again once it goes through the engine radiator. You likely will see zero improvement.
  3. #43 Re: 04+ Trans Temp (Daily Driving)
    SWPA
    According to manufacturers of coolers running standalone is less efficient than in series. I could see how that makes sense though I am not sure I buy it.
  4. #44 Re: 04+ Trans Temp (Daily Driving)
    Apr 2012
    Dayton, OH
    I wanna hear reasoning on that, maybe for like lack or airflow or something *shrugs*. At least the the fluid wouldn't be heated from the rad so it would take longer to reach the same temps I would imagine.
    2012 F150 STX
  5. #45 Re: 04+ Trans Temp (Daily Driving)
    SE Level Member 13aceofspades13's Avatar
    Oct 2013
    Ionia
    they also have aftermarket pans with cooling fins on them i have no idea how safe and efficient these are... ZZP sells them.
    "Foxy" 2008 Pontiac Grand Prix Base model, Intake, 5.5 water pump pulley, thrush turbo muffler, flipped dogbones, MSD 8.5MM super conductor Wires, Accel super coils.
  6. #46 Re: 04+ Trans Temp (Daily Driving)
    Apr 2012
    Dayton, OH
    For what ZZP charges might as well just put a bunch of chipset heatsinks all over the trans pan. It probably cools the same amount LOL.
    2012 F150 STX
  7. #47 Re: 04+ Trans Temp (Daily Driving)
    Oct 2013
    Ionia
    that would be interesting... telling someone about your modifications, "yea i put a bunch of chip set heat sinks all over my transmission fluid pan, cools the fluid down when you take it too the track!" some die hard car guy would probably look at you like a idiot.
  8. #48 Re: 04+ Trans Temp (Daily Driving)
    Oct 2013
    Ionia
    personally living in michigan i would want too run a aftermarket cooler in series rather than a stand alone, that way the engine coolant would assist in warming the transmission fluid up a little bit, that is my 2 cents.
  9. #49 Re: 04+ Trans Temp (Daily Driving)
    Arizona
    What would be the best avenue of approach is a Yblock with a on off port. So you could switch fluid to go to factory cooler or the standalone
  10. #50 Re: 04+ Trans Temp (Daily Driving)
    Apr 2012
    Dayton, OH
    Quote Originally Posted by 91parkave View Post
    I thought about this aswell, seems like too much of a hassle.
    2012 F150 STX
  11. #51 Re: 04+ Trans Temp (Daily Driving)
    GTP Level Member
    Aug 2012
    st louis park, MN
    I actually thought about something similar! Flip to stock setup for winter and in-series for summer
  12. #52 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    That's where you went wrong. You should have cut the return line if you were running in series.
  13. #53 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    Am I gonna be screwed before I fix it
  14. #54 Re: 04+ Trans Temp (Daily Driving)
    Apr 2012
    Dayton, OH
    Derp
    2012 F150 STX
  15. #55 Re: 04+ Trans Temp (Daily Driving)
    Apr 2012
    Dayton, OH
    Just run it after the rad, and if you need to re connect the line you cut just use a double barb like you did for install with clamps. Not ideal unless you wanna buy a new line.
    2012 F150 STX
  16. #56 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    Looks like I'll be taking it all apart and working on it soon. Making it stand alone
  17. #57 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    The one thing I could **** up. I duck ip
  18. #58 Re: 04+ Trans Temp (Daily Driving)
    GTP Level Member
    Aug 2012
    st louis park, MN
    I apologize if any of the material I've provided screwed you up. I edited it now, but one of my threads had a diagram with the lines shown wrong
  19. #59 Re: 04+ Trans Temp (Daily Driving)
    Aug 2013
    McDonald PA
    Quote Originally Posted by stocker View Post
    No it was my own fault. I read multiple threads and I just messed it up. No big deal
  20. #60 Re: 04+ Trans Temp (Daily Driving)
    SWPA
    It really wouldn't be a big hassle. You would essentially "tee" into the feed line and then just turn the valve one way or the other dependent on the time of year. It would be easier than going standalone, but leaving the stock lines, then barbing back into in series for winter.
    Now that it has been mentioned, I may just do that.
  1. Trans Temp too low?
    By Linebacker in forum General Tech Discussion
    Last Post: 11-13-2013, 09:00 AM
  2. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
  3. Streetable Radial Setup for Daily driving
    By gagt3100 in forum Tires & Wheels
    Last Post: 01-01-2013, 11:20 PM
  4. Temp fluctuates a lot city driving
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2012, 08:46 PM
  5. trans temp
    Last Post: 04-28-2009, 11:13 AM
