Thread: TCC repair\freshening up...
Results 1 to 20 of 63
Threaded View
  1. #1 TCC repair\freshening up...
    Feb 2013
    Missouri
    Hey everyone, at the end of June I'm driving to 2600 miles in my car, and I want to try and make sure it'll make it there, get the best MPGs, etc. I've had the TCC PWM solenoid wire (Pin 78) disconnected from the PCM for awhile now, because I have the oscillating RPM problem going up hills and all that. I know this is a band-aid fix, and I want to fix it correctly before the trip. I've read it could be any number of 3 solenoids, or even the torque converter causing the problem, so I'm not sure where to start. The transmission has 230k+ on it, and it hasn't been rebuilt to my knowledge. Other than this problem, it shifts great, I've done a flush and the DIY shift kit to it.
    I'm not sure if I want to put a new valve body in this transmission, since it potentially has 230k on it. I can pick up a transmission from pick n pull for $117, swap my diff onto it, and put it in, but that's a lot of work. Mainly because if I have to drop the subframe I'm putting an aluminum one back in, and I need to replace my oil pan since it's dented, so that'll happen since I've changing out the subframe (aluminum oil pan). THEN, also since I'm putting a new subframe in I'll want to rebuild my LCAs, since I'll need an alignment anyways. So, needless to say if I go the transmission replacement route it opens up to a LOT more work, lol. If I go this route, do the 4t65es have the same torque converters as the HDs? I seem to remember reading somewhere that they were different by 500 rpm.
    What do you guys think? Should I just replace the TCC PWM solenoid since I unplugged it and the symptoms went away?
  1. Rim repair?
    By mteschGTP in forum Tires & Wheels
    Last Post: 10-07-2013, 11:32 AM
  2. Hud repair on 04+ help
    By Grandprix202 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2013, 07:56 AM
  3. ignition repair
    By grand prix newb in forum General Tech Discussion
    Last Post: 02-09-2011, 02:48 AM
  4. how can i repair this
    By sca555 in forum General Tech Discussion
    Last Post: 10-28-2010, 07:52 PM
  5. Headlight repair
    By Mad Monkey in forum Visual/Body Modifications
    Last Post: 08-11-2009, 05:50 AM
