Thread: Hard time finding this gasket...
Results 1 to 10 of 10
  1. #1 Hard time finding this gasket...
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Hello again message board...
    I come to you once again while I am working on my GTP in need of some assistance...
    Can anyone shed some light on where or what part number the attached gasket is called/numbered?
    I am in the process of changing out my TCC/PCS/Solenoids and I am having a hard time finding this gasket...
    I have read the plethora of advice and replies about the TCC replacement and I must say, GM should pay this forum for its help!
    Any advice on the gasket would be much appreciated...
    Thanks!
  2. #2 Re: Hard time finding this gasket...
    I think this might be it
    http://parts.nalleygmc.com/products/.../24204840.html
    idk I can't find a view from the same angle as that. Check around on here http://parts.nalleygmc.com/showAssem...ssembly=368124
  3. #3 Re: Hard time finding this gasket...
    Sacramento, CA
    Thanks for the quick reply and links...
    I have looked around online and the only place I seem to find a refrence to it is eBay..
    http://www.ebay.com/itm/4T65E-4T65-E...7e746d&vxp=mtr
    Although, I got the case gasket at napa for $25 and I can't see spending the extra $ for that seal (and another case gasket)...
    I would expect to pay something around $5 - $10 (as like in your refrenced links)...
    Any info helps...
    Thanks again...
  4. #4 Re: Hard time finding this gasket...
    Apr 2011
    Vassar, Mi
    Usually that square cut seal comes with your new side cover gasket. We order side cover gaskets 5 at a time from rockauto and they always have the seal with them. They come in the seal kit too. A local transmission shop might have one on the shelf in leftover parts they could sell you for $5 or $10.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  5. #5 Re: Hard time finding this gasket...
    Sacramento, CA
    Hey thanks for the reply...
    Do you happen to have a part number for the case gasket from RockAuto? (edit -- found the gasket...at first I didn't see it under case gasket, they call it a "side cover seal")
    I'll just return this Napa one and get it from RockAuto...
    Although, I may have found it?
    Valve body cover gasket -- http://www.oehq.com/oeparts_acd24205119.htm
    Thanks again for the replys!
  6. #6 Re: Hard time finding this gasket...
    Apr 2014
    CT
    When I ordered mine from rock auto I did not get that seal!!! I had to reuse the old one! hmm I wonder if I got ripped. oh well. Anyways the square seal itself I think is this one. http://www.rockauto.com/catalog/more...006&cc=1374768
  7. #7 Re: Hard time finding this gasket...
    Sacramento, CA
    Hmm, well I returned the Napa version and purchased the seal from RockAuto...
    I will post back if I receive the seal or not...
    Thanks for the heads up paedbo...
  8. #8 Re: Hard time finding this gasket...
    Sacramento, CA
    Just to update...
    The RockAuto gasket in-fact came with the square seal...
    Although, in the process of removing the solenoids, I broke every one of the damn clips...
    I will be searching "how tos" on what others have done in this scenario...
    I was as gentle as I could be...
    FS section here I come...
  9. #9 Re: Hard time finding this gasket...
    Apr 2011
    Vassar, Mi
    If the clips on the harness all break off really easy it is usually a sign that the trans has been really hot.
  10. #10 Re: Hard time finding this gasket...
    Sacramento, CA
    Thanks for the reply...
    It did appear that the fluid was pretty low when I started messing with it...
    It also appears this harness is a 16 pin version, and I don't see one on flea bay for sale...
    All the ones on there are 14, 17, and 19 pin, all except for the "universal" version....
    I will prob be headed out to pick n pull this weekend to check out the GTPs that are there and get more grease under my nails...
    Thanks again for all the replies...
  1. hard time starting
    By kawasakidrivinghick in forum General Tech Discussion
    Last Post: 01-29-2013, 05:04 PM
  2. GTP Having a hard time shifting occasionally?
    By jwjones in forum General Tech Discussion
    Last Post: 01-09-2012, 12:26 PM
  3. Havin a HARD time
    By 2lagit2quit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2009, 05:05 PM
  4. Has a really hard time starting when engine is hot
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2008, 11:27 PM
  5. Trans has a hard time downshifting when its cold?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2008, 10:38 AM
