Thread: How much Dex 6 to have on hand to fill dry trans?
Results 1 to 6 of 6
  1. #1 How much Dex 6 to have on hand to fill dry trans?
    Feb 2008
    San Diego, CA
    Will be swapping in a rebuilt 4T65E over Xmas break.
    There's already 1 qt of Dexron 6 in the 245mm reman TC. How much more at minimum should I have on hand to be sure to get the rest of the dry trans filled?
  2. #2 Re: How much Dex 6 to have on hand to fill dry trans?
    Oklahoma
    Ive seen varying information on a dry fill total, usually ranging between 12 - 14 quarts.
    By the way, did you finish posting up all your progress work on the Bonneville Forums? If so, can you send me the link, I was tracking that pretty closely and then it seemed to go dead.
  3. #3 Re: How much Dex 6 to have on hand to fill dry trans?
    Feb 2008
    San Diego, CA
    Well it did go into hibernation, in that I finished the trans in July but am just now getting around to installing it
    Been limping along since then with some rod knock (which just went to Defcon 5) and increasingly bad slippage, just waiting for some time off to install my:
    Rebuilt 4T65E:
    BonnevillePRO.com • View topic - Rebuilding a 4T65E-HD
    and L26/M90:
    BonnevillePRO.com • View topic - My topswapped, lightly modded L26 thread
    Will be sure to have another 13-14 qts Dex 6 on hand for fill.
  4. #4 Re: How much Dex 6 to have on hand to fill dry trans?
    Oklahoma
    You dude, are simply my hero, LOL. When you do work you do some awesome documentation of what you are doing and that is great stuff. Thank you for linking to that for me.
  5. #5 Re: How much Dex 6 to have on hand to fill dry trans?
    Feb 2008
    San Diego, CA
    And in turn, TrannyMan is my hero; could not have done that as well--or as cheaply--without his advice and services.
  6. #6 Re: How much Dex 6 to have on hand to fill dry trans?
    Barksdale AFB, LA
    Reading those threads, I have to bring something up:
    An 04 L26 I recently picked up from an Impala had the standard metal pan with standard windage tray gasket.
    The 04 Impala had the L36/L26 hybrid engine. It was technically a L36 with a L26 block, crank, pistons, rods, valve train, and heads. The UIM, TB, LIM, fuel rail, electronics, oil pan, water pump, etc would be identical to the L36s.
    I may know a thing or to about that specific year L36.
    2009 Subaru Impreza WRX STI
  1. HOW TO: Hand polish engine parts
    By stlmo_gtp in forum How To Write-Ups/Tech Tips
    Last Post: 04-09-2010, 09:37 PM
  2. Hand brake?
    By whiteknuckle in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2009, 02:34 AM
  3. Wideband - first hand experiences please?
    By IndeedSS in forum PCM Tuning
    Last Post: 03-04-2008, 08:44 PM
  4. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
