Thread: Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
Results 1 to 6 of 6
Threaded View
  1. #1 Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    Dec 2013
    WORK
    Started about 2 weeks ago. Car have 80k miles
    Basically during the first 15-20 min after starting the car during warm up, the transmission will do some weird shifting
    1st gear is slipping/sluggish.
    During the 1st to 2nd gear shift the engine rev's up/rpm and the transmission seems like it's not wanting to shift properly and it's taking a long time. Basically it acts like it is trying to shift and stuck but then if I let off the pedal then press it again lightly it will shift but still sluggish. During the 1st to 2nd gear shift I noticed with the rpm it will like stall then jump up then down to shift. Its a sluggish/slipping slow shift. Sometimes it wont shift and kind of like stalls like it is trying to shift
    If i get on it a bit it will slip and suddenly catch into gear like i'm neutral dropping it, but then i won't get a surge going into second after that
    The rest of shifts 2nd and up feels like I have a shift kit which i dont mind, but they are real jerk shifts
    Now If I put the trans in 3rd gear and drive it, the transmission will shift normal
    Now when the trans is in normal drive, after the car warms up and I drive it around for a while then most of the time it will shift perfectly but I still get those fast quick jerk shifts 2nd gear and up
    Kind of seem like a bad pump,solenoid,PCS or a electronic glitch/transmission filter, I don't know. Tranny is fluid is bright and red
    i also seen this here http://www.grandprix.net/problems/Tr...pinggoing.html which he said was pinched wires. which may make sense because I just had a mechanic do a tuneup and oil change and he was working behind the the engine to get to the spark plugs..After that, i started having problems 1 week later..
  1. a quick question about the homemade shift kit
    By grandpree05 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2014, 09:04 PM
  2. Shift from park to reverse or drive, quick question
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2011, 04:20 PM
  3. Tranny is slipping real bad all of a sudden
    By Sandman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2009, 04:41 PM
  4. Tranny will not down shift
    By Uno99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-13-2009, 01:34 PM
  5. 1-2 wot slipping shift
    By solow172 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2008, 10:10 PM
