i just lost IQ points watching that vid. holy crap dude, spit it out already.
Thanks for the pictures on the trans cooler mounting and routing of the lines....it looks like you took the front bumper off....how long did it take you to do this and where were the bolts located?
Took about 10 minutes, clips all along the top and bottom, bolts on bottom and in the wheel wells.
Rob,
I installed an in-series cooler last fall and will describe my approach. I also spent way more time planning/measuring than it actually took to install the cooler. I mounted my cooler on the driver's side of the car and routed the lines around the driver's side of the ac condenser/radiator (I use these terms interchangeably which is probably wrong).
First, here is a sketch I made of my setup on a 2008 base 3.8L. The perspective is drawn from the front if you were standing slightly towards the drivers side:
http://i750.photobucket.com/albums/x...ps3ac41883.jpg
EDIT: THE LINES SHOWN ABOVE ARE INCORRECT - THE ENDS ARE LABELED CORRECTLY BUT HOW THEY CONNECT TO THE RADIATOR ARE FLIP FLOPPED. THE TOP LINE FROM THE STOCK RADIATOR IS THE RETURN LINE AND SHOULD BE TAPPED INTO.
If I remember correctly, the transmission lines connecting were metal on the ends connecting to the transmission and radiator with a segment in the middle that was the same rubber tubing as was provided in my cooler kit. This is where I tapped in. I located my cooler as directly behind the drivers side grill opening as I could. I figured this would provide the most airflow vs behind the bumper or other obstruction. I think I took a different approach to routing my lines than others but it was very clean and has worked great so far. I was able to route my lines immediately outside of the AC condenser/radiator. There was a plastic guard or brace (might be the "vertical brace" you were referring to) just outside the radiator but I was able to route my lines BETWEEN the two without kinking or breaking the 3" bend rule. Note that I actually DID route the lines high to low as they wrapped around the radiator, this softened the curve in the lines. If I were to wrap them around the condenser on a level plane I think the bends would have been too sharp. If your car has the same setup as the 2008 model you should see this once you start digging in. My lines came out at the same location where the rubber portion of the original transmission lines were located so it was easy to tap into once I got them routed through the gap.
I had to take of the big plastic bottom guard which was somewhat challenging at times. Other than that I don't think I disassembled anything else.
Let me know if you'd like more information or want pictures of my setup.
that diagram is so perfect. nice job.
Thanks alot Stocker! You just inspired me to go through with the trans cooler job! But first just a few questions....which trans cooler did you install? Do you remember the size of the rubber lines you got the copper connections for (I'm thinking 3/8 rubber line) ??
Anyways I will take off my front bumper, the bottom plastic panel, mount the trans cooler towards the driver side towards the top like you...the only difference between your 2008 and my 2000 grand prix is the supply line runs to the bottom of the radiator and return line runs from the top...Did you use the standard worm clamps with the copper connections?
Thanks a bunch for the detailed write up along with the illustration, I really appreciate it!
I did a Hayden 403 and the kit included 3/8" rubber line. I just went into NAPA and got the copper connectors - they were labeled as air hose connectors.
I know we've gone back and forth about which line is supply and return. You must have checked yours somehow? Maybe gm switched up the direction on us.
This website seems consistent with my car. http://www.grandprix.net/upgrades/cooler.html . I just don't want you to install the wrong way!
I used the standard worm/screw clamps and they have been great - not a drop leaking. I read to avoid over tightening them; stop once the hose bulges out flush with the metal band on the worm clamp. I think people tend to over tighten them and it cuts the hose.
Glad I could pass along some info :cool:
Update?
Anyone know the max pressure of the transmission coolant lines under normal operation for the 4T65-E? The video below states that max normal transmission line pressure is from 223-271 psi, and can reach 275 or more with a bad PCS. Hayden trans coolers are rated and tested for 150 psi. I know the video creator is using a scan tool to set the PCS amperage to get those pressures, but doesn't that make it risky to install a low pressure trans cooler if those kinds of pressures are possible from a malfunctioning PCS?
https://www.youtube.com/watch?v=CNjDiPFcKuU
Cooler line pressure and line pressure are two different things. Not sure how to explain it best.... They are two different hydraulic circuits. Any (decent) aftermarket cooler will be fine.
cooler is a governor bleed/lube circuit, main line pressure actuates some shuttle valves and all clutch/band apply pistons.
@Turbocharged400sbc & @BrandonHall10
Thanks. Wanted to make sure. That video threw some doubt about that. Not very familiar with transmissions, but learning more as I go.
