Thread: how many bolts?
Results 1 to 10 of 10
  1. #1 how many bolts?
    Canada
    Anyone know how many bolts there are from the bell housing to motor on the 3.8L grand prix(2005) ?
  2. #2 Re: how many bolts?
    I wanna say 6.
  3. #3 Re: how many bolts?
    Aug 2011
    'Merica
    here is where the trans bolts up to the motor in our 05
  4. #4 Re: how many bolts?
    the only one that you "won't see" is the one that goes in on the backside of the motor from the passenger side.
  5. #5 Re: how many bolts?
    Aug 2011
    'Merica
    You can see on the trans itself the holes
  6. #6 Re: how many bolts?
    Canada
    is there on on the bottom right near the manifold from the first pic? or is that just a dowel location? if there was a bolt there it looks as thou it would bolt into the transmission as in the 2nd pic it woul be the one closest to the long part where the axle to the passenger side wheel would go(right under the tie wrap)
  7. #7 Re: how many bolts?
    Aug 2011
    'Merica
    I don't remember any dowel pins, but I could be wrong
  8. #8 Re: how many bolts?
    I think there are 5 and there are 2 dowels but one i think has a bolt go through it.
  9. #9 Re: how many bolts?
    Canada
    Yes you are correct 4 bolt into the motor and 1 bolts into the tranny
  10. #10 Re: how many bolts?
    if your leaving the engine in the car, this pic shows the backwards bolt. you need a long extension to reach it from the pass side wheel well. air tools are optional.
  1. Gen V Bolts m8 x1.25 120mm and 140 mm bolts
    By 97gtpjoe in forum Wanted To Buy - Parts
    Last Post: 10-06-2013, 12:11 AM
  2. arp head bolts or tty bolts?
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2011, 10:51 AM
  3. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
