I know this is a grand prix fourm but I also know you guys are some of the best fools out there when it comes to these trans. Got a 2000 chevy venture same trans as in both of my other cars and almost all grand prix's. It will not fully shift into 4th gear driving. It will slip between 3-4th gear like the toruqe converter is not locking up fully. I had someone tell me that it is the tourqe converter sensor bad. I have looked up where they are at and it does not seem like a horible job. (just a pan drop pull the sensor out replace sensor/filter and refill) Can anyone tell me if this is true and is it that easy of a job or is there alot more too it.
Do I have to drop the valve body to change out the sensor ? Im not the best person with transmisions but im guessing I could drop the valve body by myself without f'ing it up too bad. Just need a few picks from the forums here on putting in shift kit should show me what I need to do to drop the valve body.
