Thread: Tractor oil in GP
Results 1 to 6 of 6
  1. #1 Tractor oil in GP
    Jun 2012
    Ontario Canada
    So I posted before about my car jerking while at higher rpm's. This resolved itself when I changed my MAF and cleaned my TB.
    I noticed some slippage when regular driving, so I saw lucas trans fix was mentioned earlier, I was looking at the stuff and it just looked to be a thicker oil (Probably more to it, but my logic stands).
    So, hop on down to Canadian Tire, go to the transmission oil section and see some vegetable based tractor oil, roughly the consistency of warm honey. Dumped 3/4 of the bottle in my trans and now it's smoother than it has ever been (got the car at 256km)
    Did this at about 296,000km
    just turned over 301,000 and still working great.
    Anybody have any concerns for using this type of oil, what do you think caused it to start acting normally again?
    Thanks,
    Donny
  2. #2 Re: Tractor oil in GP
    no clue what you used. so who knows?
    lucas is more then thicker fluid, it refreshes seals and stuff.
  3. #3 Re: Tractor oil in GP
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Quick question Scotty. Got a friend has a 08 GP 5.3. Put it in gear nothing but a whining noise. Pull the battery fuse for a minute and it goes in gear for awhile then its like its in neutral. Pull the fuse again and it goes in gear. Any ideas?
  4. #4 Re: Tractor oil in GP
    Quote Originally Posted by lewis1952 View Post
    im no tranny expert but im sure its got a stored code. sounds like if hes lucky its a bad solenoid. see if it moves when in 1 st gear. if it drives its the forward band that broke. most of the time.
  5. #5 Re: Tractor oil in GP
    Sep 2013
    tulsa okla
    Won't move at all til you pull the battery fuse put it back in
  6. #6 Re: Tractor oil in GP
    get it scanned. the code will tell more. seems like a solenoid. theres 3 of them in the side cover that can go bad.
  1. 2009 MTD Lawn Tractor vs. Kubota 4X4 Diesel
    By 02 WS6 TA in forum Track Sessions and Kills
    Last Post: 10-12-2012, 02:51 PM
  2. speed daddy headers vs tractor trailer tire belt
    By gtpinsc in forum Off Topic Discussion
    Last Post: 07-20-2010, 04:31 PM
  3. Tractor Fire
    By TCO in forum Off Topic Discussion
    Last Post: 07-10-2008, 11:50 PM
