Thread: Which shift kit would you recommend?
Results 1 to 9 of 9
  1. #1 Which shift kit would you recommend?
    SE Level Member oldsman105's Avatar
    Queens, New York
    There are many shift kits from the W-body store shift kit for $19.99 to the INTENSE Street/Strip Performance Shift Pak for $129.99. I am curious which is the best bang for buck? Any and all help is appreciated.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Transgo from Trannyman.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    Oklahoma
    Quote Originally Posted by IndeedSS View Post
    x10^3
    Outer Space
    Wonder how much those run.
    02 GTP 13.6 @ 100mph - SOLD
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I ran the TRANSGO from Thrasher for 6 years. Loved it.
    St Louis MO
    Quote Originally Posted by Lawngoose View Post
    shoot him a PM and ask.
    2010 Camaro SS LS3
  7. #7 Re: Which shift kit would you recommend?
    PA
    I am using the DIY shift kit and pressure turned up some with my PT and that works great for me!
    2001 GSE
  8. #8 Re: Which shift kit would you recommend?
    NY
    transgo from thrasher here too..worth the money since you get all the accum. seals and plate gasket included.(plus a filter )
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  9. #9 Re: Which shift kit would you recommend?
    Saraland Alabama
    most of the trans guys I have spoken to only use the transgo regardless of trans
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
